joeyaccount Posted February 6, 2021 Share Posted February 6, 2021 When I click on a file in a folder (Created w/ X12) Chief attempts to open. A dropdown box appears and ask for Serial #. I put in my serial number and a message appears not valid. How to make X12 the default program such that when I click on a file created in X12, X12 will open displaying the file and ready to work? Joey B Link to comment Share on other sites More sharing options...
rgardner Posted February 6, 2021 Share Posted February 6, 2021 19 minutes ago, joeyaccount said: When I click on a file in a folder (Created w/ X12) Chief attempts to open. A dropdown box appears and ask for Serial #. I put in my serial number and a message appears not valid. How to make X12 the default program such that when I click on a file created in X12, X12 will open displaying the file and ready to work? Joey B Sounds like you might have an issue. I would recommend calling chief on monday with your key number handy so they can help you resolve your issue. @Dermot Link to comment Share on other sites More sharing options...
lbuttery Posted February 6, 2021 Share Posted February 6, 2021 since I have always had multiple versions of Chief installed I select the plan to be opened via Windows explorer via right click and then select "open with" and choose which version of Chief to use for that plan in that dialog there is a setting to "always use..." for the .plan extension use this if you only want X12 to open .plan files Lew Link to comment Share on other sites More sharing options...
Chopsaw Posted February 6, 2021 Share Posted February 6, 2021 There is a new setting that was introduced in X11. Preferences>General>File Management>File Association> "Associate Files With This Program..." If that does not do it call tech support with your serial number. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 6, 2021 Share Posted February 6, 2021 ..or this... https://www.google.com/search?q=windows+10+file+associations&rlz=1C1CHBF_enUS694US695&oq=windows+10+file+association&aqs=chrome.0.0j69i57j0l8.5856j0j4&sourceid=chrome&ie=UTF-8 Link to comment Share on other sites More sharing options...
Dermot Posted February 7, 2021 Share Posted February 7, 2021 See if this tech article helps: https://www.chiefarchitect.com/support/article/KB-01131/associating-plan-layout-and-library-files-with-the-latest-version-of-chief-architect-or-home-designer.html Link to comment Share on other sites More sharing options...
joeyaccount Posted February 7, 2021 Author Share Posted February 7, 2021 Thanks to all for taking the time to reply with help. I followed the Chief instructions provided by Dermot. It worked perfectly. Joey B Link to comment Share on other sites More sharing options...
