RobWhite Posted February 1, 2021 Share Posted February 1, 2021 Is there a method for automatically generating a wall framing with double 90x45 studs @ 450 centers. I know I can produce 90x90 studs at 450 and then manually changed the studs to 45 and then duplicate the studs, but is the an auto system. My project current project only involves 1 wall so manual alternation is not a big issue, but if I were to do this for a whole house the manual adjustment would be quite involved. Link to comment Share on other sites More sharing options...
RobWhite Posted February 1, 2021 Author Share Posted February 1, 2021 I just get the detail together and attach it...in 15 mins Link to comment Share on other sites More sharing options...
para-CAD Posted February 1, 2021 Share Posted February 1, 2021 For double walls, I make a copy of a single wall that is close in type and rename it ___ - DBL WALL. Then I add all the specific wall info and when I choose it, it displays as 2 walls (like a party wall between to units of a townhome) I assume CA is treating this as one fat wall, but it generates to the final plan visually correct. Link to comment Share on other sites More sharing options...
glennw Posted February 1, 2021 Share Posted February 1, 2021 Rob, What I did was open the wall detail, select all the studs, copy, started to drag along the wall. hit Tab and entered 45. You could also use multiple copy - there is even a separate spacing for wall studs. Link to comment Share on other sites More sharing options...
RobWhite Posted February 1, 2021 Author Share Posted February 1, 2021 The above frame layout requires 2/90x35 stud to suit a wall upto 4200mm high (13'9") highest point Link to comment Share on other sites More sharing options...
Chopsaw Posted February 1, 2021 Share Posted February 1, 2021 I think you need to go with Glenn's method. It can be done in plan view or your wall detail where you will need to do the blocking. Chief will build a wall like this auto but not what you need. Link to comment Share on other sites More sharing options...
glennw Posted February 1, 2021 Share Posted February 1, 2021 Chopsaw, Yes, I deleted my first post that described and showed exactly that, but then on re-reading the OP message, I figured what he wanted. There will be some cleanup with the heights. May be better to stick with the 90x90 and draw a line down the middle and copy that. Link to comment Share on other sites More sharing options...
rgardner Posted February 1, 2021 Share Posted February 1, 2021 6 hours ago, glennw said: There will be some cleanup with the heights. This can be very fast if you take advantage of the trim to and cut to tools though. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 1, 2021 Share Posted February 1, 2021 Here's another very quick way... Place a Framing Reference Marker Frame Wall Open Wall Detail, use a marquee or fence to group select studs and Cut (Control+X) them all to clipboard Move Framing Reference Marker over 1-1/2" (or the thickness of your stud) Frame Wall again Open Wall Detail and Paste Hold Position (Control+Alt+V) Link to comment Share on other sites More sharing options...
