Primary Contours
builtright3
1 minute ago, Doug_N said:
Joe,
I misread your post.  I thought you were referring to the size of the text, not to indicate the units.  Using a note to indicate that the contour info is in feet should satisfy the plans examiner.
Yes, thank you.
The note is fine but still would like it to show it correctly if it was an easy thing to do.
