Benny_G
All lines in my design are very thick
Dear Chieftalk members,
Unfortunately I must have changed something im my general setup. All lines (not only the walls) are so thick that it is disturbing. Does anyone have an idea how to change this?
Villa Cabochon_200923_Print Screen.pdf
Kind regards,
Benny
Anyone could be a little more certain with a helpful answer IF you were to also share in your signature, what software version/title you are using. They ARE all quite different in what and how they can and cannot do things.
If you have Suite or Architectural you are SOL as they offer no line weight controls.
If you have HD Pro then you are in luck: Open your "Display Options" dialog while in Plan View and you will see there that you can choose, manually an object's "Line Weight" (darkness or lightness), the "Line Style or type" (dashed or unbroken) and the line's color, take a look, please.
Obviously, I answered this thinking I was on Home Talk but never the less what is true for Home Designer Pro is also true for Chief Premier. INo matter what Version of Chief you have my answer, relative to line appearance is the same.
It doesn't look like Layer Display Options to me.
In layout, it looks like it could be File>Print>Drawing Sheet Setup>Advanced Line Weight Options to me.
Is it set at 1/100mm or is it set at something else?
Dear DJP, sorry I added the version to my signature: I am on Premier X12.
Hi glennw,
I checke the Advanced Line Weight Options: yes it is set at 1:100 mm. I guess, this is how it should be, no?
Kind regards,
Benny
You plan file and layout file don't match. They both have to be set at the same...1:100mm..
Dear all,
Thanks for your support! I was so unhappy and figured finally myself out what was wrong. Under Preferences/Appearance/Line Weights/Minimum Display Weight: there was a 6 instead of a 1 which made all lines very thick.
Kind regards,
Benny
I personally have that set to 0.
I think most do.
Hi Michael,
Thanks for your feedback. When I changed from "1" to "0", I didn't notice any change in the design.
Do you know what the difference is between these two settings?
Kind regards,
Benny
That information is very easy to find in the help file.
Hoi Benny, the 0 just gives you the absolute thinnest line display thickness on your monitor to make it easier when you zoom far in for precise measurements etc.
For example, when placing cabinets and you want to zoom in real close to see if 2 cabinets are just touching or overlapping just enough to mess with dimension strings.
You won’t find this kind of information in the help files. Which is the reason we have a user forum. Glen must be grumpy today. (kidding)
Gents, thanks a lot to everybody who supported me. "The more I know, the more I realize what I do not know".
Cheers,
Benny
Ok, I will make it easy:
Quote
• Specify the Minimum Display Weight, in Pixels. This is the lowest line weight possible on screen, regardless of how far you zoom out. A Minimum Display Weight of 0 is the same as 1. This setting is ignored when printing or when Print Preview is enabled.
Good morning Glenn,
Thanks for the additional information. I will be happy to adjust accordingly.
Kind regards,
Benny
    28850
    ConTechTom
    ConTechTom
