BeachHouse1
Previewing layout Sheets
I hope this is me being the nut-behind-the-wheel, because if not, this is annoying.
When you open the print dialog box, it automatically Previews the entire drawing set, even if all you really want to do is print one page.
What's u[ with that?
Uncheck Update Automatically and just click Update when you have your desired page selected.
  • Like 2
I'd sometimes wondered if I was unique in doing that because my computer was too slow or something.
Sometimes (can't figure out the trigger) you don't even have to update in order to print.
Nope, you're not alone.  I have that setting turned off by default.
AFAIK Chief runs the Update before it Prints anything to make sure everything is upto date in the Layout before wasting (expensive) Ink.....but why I Print to PDF too 1st.
Click the current page button and all the other pages go away.
I'm referring to the print dialog box not the individual layouts.
Does your suggestion still apply?  Thanks.
True, but only after it goes through every sheet prior to alloying changes to the print options.
I'm hoping to disable this feature until the which sheet to print has been selected.
This may help a little.
You could then go back to Drawing Sheet Setup and check Remember Print Settings After Printing.
Uncheck Update Automatically.
This will remember the Current Sheet setting and will only display the current sheet.
Downside is that it will remember the other settings as well - but that may not be a problem if your print jobs use the same settings.
    28426
    JosephIM
    JosephIM
