Auto Build Roof Framing - Default
stevenyhof
I'm not sure if this is a bug, but when I set the defaults for the roofs to auto build roof framing, it works after I set it for the following roofs I build. But when I open the plan again to work on, I need to set this default back on. ???
If you are talking about your template plan then you would need to re-save the file as your new template.  Unless you are referring to a file that already has roof planes...   That would be a longer story.
11 minutes ago, Alaskan_Son said:
Might sound like a silly question but just to make sure, you are clicking OK and not just closing or canceling the dialog box right?
Yes. Now I am opening the Build Roof first to make sure of my settings and it works from there. Maybe I am doing something that is causing the default to reset ???
Only thing I know of that can cause that problem is you manually modifying framing in one way or another and then clicking "Yes" to the "The current operation modifies a roof framing member....Would you like to turn off Automatic Roof Framing and continue with this operation?" question.
Very possible! Now I need to figure out how to turn it back on - the browser is not letting me upload my plan.
Maybe I need to go back to an archive.
Michael, I think I need to retain your services for things like this.
Because I also built my roof over the main floor, but now I want to put dormers in the second floor and I'm not real sure how to cut my roofs on other planes. I know i seen a video on moving roofs to another floor - but I cant find it back
10 minutes ago, GeneDavis said:
Move roof up or down a floor is a button icon at bottom dialog box when you've selected a plane or planes.
This has has been a nice learning opportunity. I love that you can move roofs up or down to work on additional roofs. That is amazing to me.
Just for the record, I was turning the auto build rafters off <_<
You have to have the file closed out of Chief before you can send it or upload it anywhere.
Chief locks Files while open , so you can't upload it while open in Chief.
Just to Clarify ...Chief doesn't actually move the Roof Planes up or down, it just displays them on a different floor for you so you can work on them easier eg joining them etc....
Or when you need to send ALL planes to Layout and show then on a 1 page "Roof Plan" View some jurisdiction like.
Yes, that is what I find so amazing!
