Steve_Nyhof Posted August 3, 2020 Share Posted August 3, 2020 I'm not sure if this is a bug, but when I set the defaults for the roofs to auto build roof framing, it works after I set it for the following roofs I build. But when I open the plan again to work on, I need to set this default back on. ??? Link to comment Share on other sites More sharing options...
Chopsaw Posted August 3, 2020 Share Posted August 3, 2020 If you are talking about your template plan then you would need to re-save the file as your new template. Unless you are referring to a file that already has roof planes... That would be a longer story. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 It is a plan from my template which does not have it selected. But after creating a new plan (from the template) I set the defaults to build rafters. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 And now I am finding it un-checks when I leave the plan view to a 3d view and go back. That does not seem right to me. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2020 Share Posted August 3, 2020 Might sound like a silly question but just to make sure, you are clicking OK and not just closing or canceling the dialog box right? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 11 minutes ago, Alaskan_Son said: Might sound like a silly question but just to make sure, you are clicking OK and not just closing or canceling the dialog box right? Yes. Now I am opening the Build Roof first to make sure of my settings and it works from there. Maybe I am doing something that is causing the default to reset ??? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 3, 2020 Share Posted August 3, 2020 6 minutes ago, stevenyhof said: Maybe I am doing something that is causing the default to reset ??? Only thing I know of that can cause that problem is you manually modifying framing in one way or another and then clicking "Yes" to the "The current operation modifies a roof framing member....Would you like to turn off Automatic Roof Framing and continue with this operation?" question. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 1 minute ago, Alaskan_Son said: Only thing I know of that can cause that problem is you manually modifying framing in one way or another and then clicking "Yes" to the "The current operation modifies a roof framing member....Would you like to turn off Automatic Roof Framing and continue with this operation?" question. Very possible! Now I need to figure out how to turn it back on - the browser is not letting me upload my plan. Maybe I need to go back to an archive. Michael, I think I need to retain your services for things like this. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 Because I also built my roof over the main floor, but now I want to put dormers in the second floor and I'm not real sure how to cut my roofs on other planes. I know i seen a video on moving roofs to another floor - but I cant find it back Link to comment Share on other sites More sharing options...
GeneDavis Posted August 3, 2020 Share Posted August 3, 2020 Move roof up or down a floor is a button icon at bottom dialog box when you've selected a plane or planes. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 I think I figured it out. My roof was on the attic level. The rafters seem to show on the floor below - I also found the tools to raise the roof to another level to work on Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 10 minutes ago, GeneDavis said: Move roof up or down a floor is a button icon at bottom dialog box when you've selected a plane or planes. This has has been a nice learning opportunity. I love that you can move roofs up or down to work on additional roofs. That is amazing to me. Link to comment Share on other sites More sharing options...
GeneDavis Posted August 3, 2020 Share Posted August 3, 2020 Watch the training video "Roof Design Strategies." Very useful info. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 2 minutes ago, GeneDavis said: Watch the training video "Roof Design Strategies." Very useful info. I will do it now - Thank you Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 3, 2020 Author Share Posted August 3, 2020 1 hour ago, Alaskan_Son said: Only thing I know of that can cause that problem is you manually modifying framing in one way or another and then clicking "Yes" to the "The current operation modifies a roof framing member....Would you like to turn off Automatic Roof Framing and continue with this operation?" question. Just for the record, I was turning the auto build rafters off 1 Link to comment Share on other sites More sharing options...
rgardner Posted August 4, 2020 Share Posted August 4, 2020 3 hours ago, stevenyhof said: Very possible! Now I need to figure out how to turn it back on - the browser is not letting me upload my plan. Maybe I need to go back to an archive. Michael, I think I need to retain your services for things like this. You have to have the file closed out of Chief before you can send it or upload it anywhere. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 4, 2020 Author Share Posted August 4, 2020 12 hours ago, rgardner said: You have to have the file closed out of Chief before you can send it or upload it anywhere. Thank you! I should have thought of that Link to comment Share on other sites More sharing options...
Kbird1 Posted August 5, 2020 Share Posted August 5, 2020 On 8/3/2020 at 3:50 PM, stevenyhof said: Very possible! Now I need to figure out how to turn it back on - the browser is not letting me upload my plan. Maybe I need to go back to an archive. Michael, I think I need to retain your services for things like this. Chief locks Files while open , so you can't upload it while open in Chief. On 8/3/2020 at 4:11 PM, stevenyhof said: This has has been a nice learning opportunity. I love that you can move roofs up or down to work on additional roofs. That is amazing to me. Just to Clarify ...Chief doesn't actually move the Roof Planes up or down, it just displays them on a different floor for you so you can work on them easier eg joining them etc.... Or when you need to send ALL planes to Layout and show then on a 1 page "Roof Plan" View some jurisdiction like. M. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted August 5, 2020 Author Share Posted August 5, 2020 18 hours ago, Kbird1 said: Just to Clarify ...Chief doesn't actually move the Roof Planes up or down, it just displays them on a different floor for you so you can work on them easier eg joining them etc.... Yes, that is what I find so amazing! Link to comment Share on other sites More sharing options...
