eubanks Posted June 9, 2020 Share Posted June 9, 2020 Good evening everyone, hope you are all well! I have had this problem for awhile and I have searched the forums for this issue before. The living room shown in the jpeg is a 2-story height space in a tiny home (84" first floor, 60" Loft). I want to have the electrical layout displayed on the ground floor and also have the recessed lights in the vaulted ceiling in the floor above. The problem is the vaulted ceiling is drawn on the 2nd floor. The obvious workaround is to draw these fixtures on the 2nd floor, CAD to detail, and copy them as a separate layer on the ground floor. It is important that the client sees the lights in relation to furniture, cabinets, etc. Let me know if it is possible to combine the first and second floor into one room in the living room. As you can see in the photo, the ceiling is registering only 84" above the floor. Thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted June 9, 2020 Share Posted June 9, 2020 Use a Reference Layer on level 1 with only Electrical displayed from floor above ? M. 2 Link to comment Share on other sites More sharing options...
DzinEye Posted June 10, 2020 Share Posted June 10, 2020 14 minutes ago, Kbird1 said: Use a Reference Layer on level 1 This^^^ 1 Link to comment Share on other sites More sharing options...
eubanks Posted June 10, 2020 Author Share Posted June 10, 2020 Thanks Mick and Mark! I just set up the reference floor set, and this is going to work perfectly!! Cheers, Chris. Link to comment Share on other sites More sharing options...
mtldesigns Posted June 10, 2020 Share Posted June 10, 2020 Curious on why you didn't do the vaulted on the first floor? Is this why your lights look flat instead of matching ceiling slope? Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 10, 2020 Share Posted June 10, 2020 8 minutes ago, mtldesigns said: Curious on why you didn't do the vaulted on the first floor? Is this why your lights look flat instead of matching ceiling slope? 1 hour ago, eubanks said: Thanks! What Michael said. Why is there a second floor and why is electrical placed on that floor? Seems that your method may be flawed Link to comment Share on other sites More sharing options...
Ridge_Runner Posted June 10, 2020 Share Posted June 10, 2020 8 minutes ago, Renerabbitt said: Why is there a second floor and why is electrical placed on that floor? Maybe he thought they had to go on the 2nd floor which was created because of the loft. Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 10, 2020 Share Posted June 10, 2020 10 minutes ago, Ridge_Runner said: Maybe he thought they had to go on the 2nd floor which was created because of the loft. I would use a room divider to define the vaulted area, then select no ceiling in the designated vaulted area's room structure dbx. No need for a reference plan as electrical in the loft if their is one would show up on the wrong floor which would be wrong. @Kbird1 and @DzinEye Sorry Mick and Mark, don't agree with the recommendation. Edit: See Eric's solution below Link to comment Share on other sites More sharing options...
Ridge_Runner Posted June 10, 2020 Share Posted June 10, 2020 2 minutes ago, Renerabbitt said: No need for a reference plan as electrical in the loft if their is one would show up on the wrong floor which would be wrong. Completely agree. Link to comment Share on other sites More sharing options...
DzinEye Posted June 10, 2020 Share Posted June 10, 2020 1 hour ago, Renerabbitt said: Sorry Mick and Mark, don't agree with the recommendation. I didn't look at his plan, I just knew using the reference would do what he needed and figured he had his reasons for doing whatever he did with floor levels. Both methods work, but of course it's always good to point the OP in the right direction to do things from the get-go. Now he knows TWO new things... so all the better. Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 10, 2020 Share Posted June 10, 2020 5 minutes ago, DzinEye said: I didn't look at his plan, I just knew using the reference would do what he needed and figured he had his reasons for doing whatever he did with floor levels. Both methods work, but of course it's always good to point the OP in the right direction to do things from the get-go. Now he knows TWO new things... so all the better. Downvote , haha...Love you MJ!! 1 Link to comment Share on other sites More sharing options...
dshall Posted June 10, 2020 Share Posted June 10, 2020 I would use a second floor to show the. clerestory windows. I would probably put the roof on level 2, I would probably put electrical on level 2 and use ref layer to show elec at first floor. The. house is a two story. Link to comment Share on other sites More sharing options...
MJLDesignsLLC Posted October 23 Share Posted October 23 Hello! I am needing help on a similar topic. I am working on a whole home electrical plan that has a two story living room. I have the electrical symbols for the living room on the second floor but the switching is on the first floor... I tried creating a reference layer like suggested above but it then displayed all the second floor lighting. Is there a way to isolate by room? Or a better way to go about showing the lighting in general? Link to comment Share on other sites More sharing options...
