A Row Of Trees
Rich_Winsor
OK, does anybody have an easy peasy way to arrange
160 3D Italian Cypress trees evenly spaced along a 500
foot road so that they vary from 8 feet tall at one end to
30 feet tall at the other end and no two trees look alike?
Yeah, I didn't think so.  ;)
evenly spaced along a 500 foot road
Rich:
Chief can do this using the distributed path tool
or the multi-copy tool
as for the variation in height ???
probably have to be done manually
as for the no look-alike - that would have to be done manually
maybe Landscape Pro can do it  ???
http://prolandscape.com/en/software/
Lew
In the Distributed Path dbx, you can specify the Angle as Random which helps hide their "sameness" when they were all oriented the same way.
Nice suggestion about the angle,  but wouldn't this only apply to 3d trees and not 2d trees?
It depends on if you want to pay someone for this task. If you have budget for this go to this website and post it as a job
http://www.creativecrash.com/#
This is a pretty simple script although you will probably want to provide several trees for the distribution so they don't have to code an actual tree. There are other websites that specialize in freelancers for film and modeling projects of this sort.
It may be as easy as taking your distributed path of trees with the slight rotation into a proper 3d modeling package and just putting a modifier box around the group to stretch asymmetrically in Z at one end. I suspect you could do this in Sketchup but I am not very familiar with the program. I do know you could do this stretch easily in Maya or Max.
OK, here’s the poop. First off thanks for all
the suggestions. I had a play with this over
the weekend and this is what I came up with.
As suggested, there are several ways to go
about spacing out and rotating a row of trees.
But… but… but… there is no way I can find to
automagically vary the heights of the trees.
I’m a visually oriented guy and I start to glaze
over when I’m 700+ pages into the manual and
trying to sort out Absolute and Relative angles,
so I prepared a little demonstration with a
generic tree fitted with a dorsal fin to aide in
observing the changes in object orientation.
In the end I used a combination of approaches.
I broke the trees into 8 groups of 20 trees each
which also happens to be way they are laid out for
irrigation purposes. Then I created 8 Polyline
Distribution Paths using the Random Angle Object
Orientation and increasing the mean height of the
trees in each path to create a stair step effect.
I chose the Polyline Distribution Path over the
Transform/Replicate option because it offered
the Random Angle feature. Finally, (and Glenn
neglected to mention this  ;)), I exploded the
Distributed Objects which enables the selection
of individual trees again and manually adjusted
the heights of about 75% of them to get the
desired ascending – descending effect for the
whole line of trees.
I won’t bore you with how long this process took
but suffice it to say that if I was hiring Bryce
to do it I would be out hundreds of dollars. :)
Anyhoo, there they are. 160 trees with no 2 alike.
BTW, this is for a site plan I am working on for
my spread here. The area encompassed by the
fence is exactly 2 acres and contains all of the
structures on the property. I still have several
structures and dozens of trees to add to the
plan (file size is currently 18MB and climbing).
Rich:
nice "compound"
with all the fencing study your walk flows and ensure you have easy access to various areas
without having to "go the long way" just to get there
is there access for large trucks - say a tree cutter to get to most sections of the site ?
I have 2/3 acre and have a 12' wide double gate at the front for large vehicles
been here 2 years and so far had a cement mixer for an addition and a tree truck
also had my pre-built shed delivered and dropped on site
Lew
I like that the distributed paths/regions can (somewhat) randomize the angles and positions.  It would be even better if you randomize the sizes too.  I'm thinking something like putting in a min and max height and let the program set them for you.  This would have made what you were doing way easier.  You should make a suggestion for this.
Rich:
nice "compound"
Lew
I am truly blessed Lew. With all the good and bad decisions
we end up making in life, somehow I managed to land on my
feet in making perhaps the biggest decision of all, where we
are going to live.
Funny you should mention fencing and walk flows. After about
2 weeks on the property I made my first major investment and
bought myself a Honda Recon ATV. I haven't regretted it for
one moment since :). The fences were all erected by the
dear little lady who previously owned the place. She was a
legend in the neighborhood on her tractor with her post hole
digger. The fences do help control the flow of wild critters
across the property.
Here is a rafter of the local gals out for their morning constitutional.
I would love to have the capability to be able to
vary the sizes of distributed objects as well as the
spacing and rotational angle, however I'm not sure
I have the total grasp of the concepts necessary
to make a feasible request.
It's always interesting to me just what computer
programs think "random" is. One could make the
argument that any combination is possible. It
just depends on the size of the sample and the
time over which it is taken. It's the old "room full
of monkeys banging away at typewriters" that
would eventually write all the great works of
literature if given enough time deal.
Actually I have had this sick idea festering in the
back of my mind that I should vary the heights of
the trees to exactly correspond to the heights of
the actual trees. This of course would require me
to individually edit all 160 trees.  Aaarrrggghhh!
BTW, to update that room full of monkeys deal
maybe it would be more appropriate to speculate
that a room full of monkeys at the keyboard with
Chief could eventually design the Taj Mahal. :huh:
