DzinEye Posted March 6, 2020 Share Posted March 6, 2020 I have to believe that I have been missing some basic Chief action all these years, so finally I'm going to embarass myself to ask... How does one align an entire cad shape/polyline, not just a selected edge of that shape? Link to comment Share on other sites More sharing options...
robdyck Posted March 6, 2020 Share Posted March 6, 2020 Just now, solver said: Probably an easier way ... I'll get the angle of the line, then rotate the shape to match. And then try to remember that a negative angle rotation is clockwise and positive is counter-clockwise...which is also counter-intuitive! I've wondered the same thing as the OP many times (including a few minutes ago). I hope a solution shows up. Link to comment Share on other sites More sharing options...
DzinEye Posted March 6, 2020 Author Share Posted March 6, 2020 Thanks Eric... that seems primitive when we have the align/make parallel tool, but it certainly works! Link to comment Share on other sites More sharing options...
DzinEye Posted March 6, 2020 Author Share Posted March 6, 2020 4 minutes ago, robdyck said: And then try to remember that a negative angle rotation is clockwise and positive is counter-clockwise If you use 'absolute' then you won't have to remember pos./neg. BUT it still seems such a primitive way of doing it, when it should just be a matter of a couple clicks. Link to comment Share on other sites More sharing options...
robdyck Posted March 6, 2020 Share Posted March 6, 2020 1 minute ago, DzinEye said: If you use 'absolute' then you won't have to remember pos./neg. BUT it still seems such a primitive way of doing it, when it should just be a matter of a couple clicks. Yeah, you still do. If I have an irregular pie shaped lot that I'd like to rotate an absolute angle, I'll have to know if it's a positive angle or a negative angle when entering the value using the transform / replicate tool. Example, the lot I'm currently working with has one side that is 1.27964 degrees off of north. I'd like that side of the lot aligned with my building. So to rotate it, I'll need (in this case) a negative rotation of 1.27964. A positive rotation of that amount would make it 2.55928 degrees off. What we need is a make parallel tool that function like the point-to-point move tool. Select objects to make parallel, then select angle 'A' to make parallel with angle 'B'. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2020 Share Posted March 6, 2020 31 minutes ago, DzinEye said: I have to believe that I have been missing some basic Chief action all these years, so finally I'm going to embarass myself to ask... How does one align an entire cad shape/polyline, not just a selected edge of that shape? Double click on the Make Parallel/Perpendicular tool (or just click it a second time). 1 3 Link to comment Share on other sites More sharing options...
rwdozier Posted March 6, 2020 Share Posted March 6, 2020 Easy! That's awesome Alaskan_Son! I knew I had seen that dialog box at some point in the past and I was challenged to try and figure it out. Thanks!!! Link to comment Share on other sites More sharing options...
robdyck Posted March 6, 2020 Share Posted March 6, 2020 7 minutes ago, Alaskan_Son said: Double click on the Make Parallel/Perpendicular tool I see that works for a single polyline only.. not multiples, correct? Link to comment Share on other sites More sharing options...
DzinEye Posted March 6, 2020 Author Share Posted March 6, 2020 1 minute ago, Alaskan_Son said: Double click on the Make Parallel/Perpendicular tool Ha!... great! Thanks Michael. Grrr... I did not see that in the Parallel/Perp tool description. Now looking with more scrutiny I see at the very end there's a link to another page describing that function. Seems to me that info should be on the same page or mentioned earlier in the tool description. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2020 Share Posted March 6, 2020 9 minutes ago, robdyck said: I see that works for a single polyline only.. not multiples, correct? Not sure what you mean, but if you select multiple polylines and try to Make Parallel/Perpendicular, you won't get the option they will automatically Rotate Entire Polyline because there is no Selected Edge to work with. Link to comment Share on other sites More sharing options...
robdyck Posted March 6, 2020 Share Posted March 6, 2020 Just now, Alaskan_Son said: Not sure what you mean, but if you select multiple polylines and try to Make Parallel/Perpendicular, you won't get the option they will automatically Rotate Entire Polyline because there is no Selected Edge to work with. That's what I meant. I typically have a fair bit of my site plan drawn while the lot perimeter is positioned relative to its north bearing. Then I'll rotate the group of objects for building placement. Still, good to have that tip about double-clicking the make parallel tool! Link to comment Share on other sites More sharing options...
DzinEye Posted March 6, 2020 Author Share Posted March 6, 2020 15 minutes ago, robdyck said: Yeah, you still do. If I have an irregular pie shaped lot that I'd like to rotate an absolute angle, I'll have to know if it's a positive angle or a negative angle when entering the value using the transform / replicate tool. Example, the lot I'm currently working with has one side that is 1.27964 degrees off of north. I'd like that side of the lot aligned with my building. So to rotate it, I'll need (in this case) a negative rotation of 1.27964. A positive rotation of that amount would make it 2.55928 degrees off. What we need is a make parallel tool that function like the point-to-point move tool. Select objects to make parallel, then select angle 'A' to make parallel with angle 'B'. Rob, if you select the edge of your lot that you want to align with your building, and in the transform/replicate dbx enter 1.27964 as an absolute angle it should work. If you entered as a relative angle, then you're correct it'll either add or deduct that angle from it's current position. 1 Link to comment Share on other sites More sharing options...
robdyck Posted March 6, 2020 Share Posted March 6, 2020 6 minutes ago, DzinEye said: Rob, if you select the edge of your lot that you want to align with your building, and in the transform/replicate dbx enter 1.27964 as an absolute angle it should work. If you entered as a relative angle, then you're correct it'll either add or deduct that angle from it's current position. Yup, you're correct. I'm using the relative angle as I'm rotating a mostly completed site plan which is multiple objects. Link to comment Share on other sites More sharing options...
DzinEye Posted March 6, 2020 Author Share Posted March 6, 2020 3 minutes ago, DzinEye said: Rob, if you select the edge of your lot that you want to align with your building, and in the transform/replicate dbx enter 1.27964 as an absolute angle it should work. If you entered as a relative angle, then you're correct it'll either add or deduct that angle from it's current position. Wait... you need to use the absolute angle of the building wall... which I think is actually 358.72036 based on what you're saying. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2020 Share Posted March 6, 2020 There's another tool you guys can be using as well... The angular dimension tool. This will allow you to reference 2 specific edges and move as many objects as you like. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 6, 2020 Share Posted March 6, 2020 I don't think I saw it mentioned, but beside the double click method mentioned by Michael earlier, you can shift select your polyline and then use the make parallel/parallel tool 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2020 Share Posted March 6, 2020 10 minutes ago, Renerabbitt said: I don't think I saw it mentioned, but beside the double click method mentioned by Michael earlier, you can shift select your polyline and then use the make parallel/parallel tool The problem with this method is that it uses the bounding box of the polyline and not a specific edge. Link to comment Share on other sites More sharing options...
Renerabbitt Posted March 6, 2020 Share Posted March 6, 2020 6 minutes ago, Alaskan_Son said: The problem with this method is that it uses the bounding box of the polyline and not a specific edge. Bounding box being plan north, useful to know for anyone finding this, easy to make a 90 degree corner perpendicular to a reference in this way. Link to comment Share on other sites More sharing options...
tommy1 Posted March 6, 2020 Share Posted March 6, 2020 3 hours ago, DzinEye said: How does one align an entire cad shape/polyline, not just a selected edge of that shape? Click the edge of the polyline you want to make parallel and then dble. click the make parallel tool and select "rotate entire polyline". Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 6, 2020 Share Posted March 6, 2020 2 hours ago, tommy1 said: Click the edge of the polyline you want to make parallel and then dble. click the make parallel tool and select "rotate entire polyline". This^^ Link to comment Share on other sites More sharing options...
