How To Build A Shower Wall Half Tile Half Glass?
4hotshoez
I would use a Glass Railing Wall 8' high for the enclosure with a Glass Slab Door for the enclosure.  Then I'd create another 42" tall railing wall for the tiled area, make it "No Locate" & "No Room Definition" and move it into place.  The other option for the tiled wall is to create it out of a Cabinet.
One thought was doing the 42" tile wall as a railing wall with the rail flattened and made to be tile, then use a polyline solid for the glass panel above. Does this method create issues in the model? I have not yet created the glass panels.
I was able to put in a glass door. I made the wall a railing wall 42" high. When I placed the door it came in as an opening. After making some manual changes to the door it was set to 42" tall. I was able to make it 96" tall. and added hardware back in. The glass above is a Polyline solid. The one problem is that to center the door I needed to make it swing both ways. So aligning the glass door is less controllable.
  • 2 weeks later...
  • 7 months later...
