Todd-W3Design Posted December 26, 2021 Share Posted December 26, 2021 I have been using a BLK360 for year now. Accuracey is 1/16", great tool! I work on projects that are hours away. I make the trip and do a detailed scan of the project so I have every dimension collected in the point cloud 3D model with google streep map like 360 photos. I essentially come back to the office with the entire as built project in point cloud form with every measurement I could need. I really wish CA would add point cloud attachment into the program. As it is now I use Autodesk Recap and can quickly measure anything I need. I have not missed any measurements the require another site visit. I don't need to run around taking tones of pictures. I get others who make a trip to the site calling asking for measurements they did not get. The as built set comes together very quickly and move into design. I know others will say they still prefer to make the site visit and laser measure everything. Everyone has their prefered method. Go for it! Link to comment Share on other sites More sharing options...
SH_Canada Posted December 27, 2021 Share Posted December 27, 2021 8 hours ago, Todd-W3Design said: I have been using a BLK360 for year now so how do these things work when there are bushes all the way down the side of a property? do you use it interior as well? how does it capture around corners for tight bathrooms? i survey some very convoluted houses. Are you assuming for instance, the inside length of a closet, becuase it cannot possibly know that with a bunch of clothes in it? 9 times out of ten that how I find the flue 1 Link to comment Share on other sites More sharing options...
IvanCyr Posted September 12, 2022 Share Posted September 12, 2022 Curious if anyone knows if there's been any further progress with imports into Chief using BLK360 or similar point cloud technologies. Interested in knowing if Chief yet or plans to use exports (registered) of E57 and RCP or LGS equivalents. Comments welcome. Link to comment Share on other sites More sharing options...
Michael_Gia Posted September 12, 2022 Share Posted September 12, 2022 Let's say you just built the Burj Khalifa, and after construction you realize there are a million things that need regular servicing after construction and then you also notice that these millions of things are not necessarily what was specified (because things change during construction) so it would be nice to have a visual of exactly what all this equipment is and where it is precisely in your building. This is probably a scenario where Point Cloud is really useful and where the client would have the money and necessity to improve his BIM so that maintenance could be most efficient. I don't think Chief users fit this description despite our longing to be relevant in this field. Let's be serious... Link to comment Share on other sites More sharing options...
SHCanada2 Posted September 12, 2022 Share Posted September 12, 2022 5 hours ago, IvanCyr said: Curious if anyone knows if there's been any further progress with imports into Chief using BLK360 or similar point cloud technologies. Interested in knowing if Chief yet or plans to use exports (registered) of E57 and RCP or LGS equivalents From some of the floor plans I have seen put together by these programs, they look to have a method to deal with the "numbers do not add up" problem. From what I can see, these programs will then make interior walls thicker to ensure the outside perimeter walls are straight. or reduce the size of an interior room. I'm not sure how that would look like in a CA import. I suppose CA could ask "what wall would you like here because the wall width is 7 5/8" in the import file" type of questions. To me its almost like these programs are a great backup resource so one does not have to go back to site, or maybe less chance of going back to site. But I think either way you cut it, someone will need to take crucial measurements at site, and will need to draw or fix up any output it produces. For something like a realtor floor plan, I think it fits the bill, or during construction to see what is in the walls, hole locations, etc. Most houses here have 10 or so rooms, it does not take that long with a laser measuring tool to do it. For the times I have been allowed, I sit their with my laptop in CA and do the plan right there. That is what I have found is the most efficient, if one can do it. but I do like the though of a backup, if I had to go back and check something out Link to comment Share on other sites More sharing options...
KTKArch Posted September 12, 2022 Author Share Posted September 12, 2022 Clarification: "Import" is a point by point intake of a file. Just as when we import a .jpeg or .pdf it is a graphical entity with it's own data and shapes. Importing a data cloud would get you a data cloud in Chief. "Converting" or "translating" a data cloud or any program's file is the process of creating Chief elements like wall types and windows/doors, floors, etc. much like 'Convert to Wall' does for cad lines. In a typical data cloud what you have is a 'random/incomplete' but orderly grouping of points that represent what the scanner has seen. Following the concept of what you put in is what you get out - If there are items in the way such as bushes or hanging clothes, move around them or move them to the best of your ability. At thousands of points per square foot, many are likely to be the wall behind, enough to at least get an accurate surface representation that will prove valuable. - Putting a little work into the prep or actual taking of the scan can yield exponential benefits. This would easily become the as-built file that could be referenced while tracing only what you needed and adding your new design elements becomes the working model. Arguably, having something that accurately represents the existing landscaping would personalize the project for your client and could easily increase the marketability of your services. Typical Chief Users may never need or want to do something like this, until its available and easy, just like rendering has become. But for the ever increasing power of personal computers we could all still be using ink pens and mylar and slide rules, if we remained satisfied with the typical. Keep pushing Chief and keep improving your own level of typical. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 12, 2022 Share Posted September 12, 2022 15 minutes ago, KTKArch said: until its available and easy It currently is both available and easy Link to comment Share on other sites More sharing options...
KTKArch Posted September 12, 2022 Author Share Posted September 12, 2022 26 minutes ago, Renerabbitt said: It currently is both available and easy In many ways with third party programs, agreed. Within Chief?...That is my intended context, even going back to my original scope of this thread. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 12, 2022 Share Posted September 12, 2022 1 hour ago, KTKArch said: In many ways with third party programs, agreed. Within Chief?...That is my intended context, even going back to my original scope of this thread. Just convert your BLK file to OBJ with textures and import straight into chief, pretty easy to trace in 3d from there using a section plane cut Link to comment Share on other sites More sharing options...
KTKArch Posted September 12, 2022 Author Share Posted September 12, 2022 20 minutes ago, Renerabbitt said: Just convert your BLK file to OBJ with textures and import straight into chief, pretty easy to trace in 3d from there using a section plane cut Thanks. Sounds like that may be similar to part of what IvanCyr was asking earlier. 9 hours ago, IvanCyr said: Curious if anyone knows if there's been any further progress with imports into Chief using BLK360 or similar point cloud technologies. Interested in knowing if Chief yet or plans to use exports (registered) of E57 and RCP or LGS equivalents. Comments welcome. Link to comment Share on other sites More sharing options...
lbuttery Posted September 14, 2022 Share Posted September 14, 2022 Photogrammetry software is another choice https://all3dp.com/1/best-photogrammetry-software/#photomodeler not as costly as point cloud devices Lew Link to comment Share on other sites More sharing options...
HienTranMiTek Posted October 27, 2022 Share Posted October 27, 2022 Hello My client requested the CA as-built model and sent me the RCP file. Does the RCP file format likely function with CA software, is what I'm wondering. If anyone has any advise, I would greatly appreciate it. Thanks Link to comment Share on other sites More sharing options...
HienTranMiTek Posted October 27, 2022 Share Posted October 27, 2022 On 11/12/2019 at 7:19 AM, KTKArch said: So I just returned from a demonstration of current high tech and its use in the future of home design. I must say, Point Clouds from laser scans are the way to go. Sure the high end is 1/4 million $ scanners and drones/aircraft. But even a $75K backpack scanner at the right resolution will take a 6-hour site measure and office drafting time down to a 30-minute walkthrough/around and 1 - 2 hours in the office for 3D overlay. Can't put out $75K...hire it out and markup 3rd party's price for the walkthrough. You not only get the building but the topography as well. Fences, trees, and neighboring buildings will get picked up. Great for landscaping and the all-important tree schedule. You will be able to simply measure tree trunks at whatever height the local jurisdiction requires from the comfort of your desk. If you find any boundary markers. Put a recognizable 3D item over them to locate them in the point cloud. Want to verify the scale of the point cloud? Measure one or more items that you can verify later and scale as needed. Better resolutions reduce and eliminate this but dramatically increase your file size. So a good scan will be within a 1/2" of accuracy and you know those pesky double-thick interior walls you can't get to? Or that one that goes off at an angle or stairs that follow a curving wall. No guessing the radius or if there are multiple slopes on the roof. Its all in the point cloud at less than half the time and cost of hand measuring. Still can't 'see' it? Watch when the countertop installer measures up the next kitchen with one. The countertop fits like a glove after a simple scan is fed into the CNC machine. If the countertop installer can make it work we can too. So Chief Architect, when are you going to simplify importing point clouds into CA? Hello, Same question as you do. I know it been a long time ago. but do you have the answer for this yet. I am current work on the X14 and my client is expecting to have an as-built molding by True Point supplied. Please advise if you have any suggestion for importing the RCP point cloud into CA. Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 27, 2022 Share Posted October 27, 2022 8 hours ago, HienTranMiTek said: Hello, Same question as you do. I know it been a long time ago. but do you have the answer for this yet. I am current work on the X14 and my client is expecting to have an as-built molding by True Point supplied. Please advise if you have any suggestion for importing the RCP point cloud into CA. Needs to be converted to an obj file type and then imported 1 Link to comment Share on other sites More sharing options...
HienTranMiTek Posted October 28, 2022 Share Posted October 28, 2022 7 hours ago, Renerabbitt said: Needs to be converted to an obj file type and then imported Thank you very much. I do have one more brief question regarding the converted file. Does the Obj file actually contain live 3D points from the scan file, or is it just a 3D block visualization? Is there a way to import the RCP file from the laser scan directly into CA? Instead, we strive to avoid converting to obj using third-party construction tools like CAD or Revit. Many thanks for your response. Link to comment Share on other sites More sharing options...
EmpireDrafting Posted February 12, 2025 Share Posted February 12, 2025 This has been a conversation for a while. Would like to use a lidar point cloud for our Site Measures, or rather, be able to off load that portion of our work to companies that provide that services. Price point is coming down. I know Chief is not Revit (yea!) but that could save us a few hours a month... thanks! Michael Payne Link to comment Share on other sites More sharing options...
SHCanada2 Posted February 12, 2025 Share Posted February 12, 2025 may I ask what they are charging you, and what they are using? I did a bunch of research last year and to get an accurate point cloud for exterior looked to require 20K or more worth of leica hardware. Interior looks like lots of options from $10 to $200 a plan for decent accuracy (within a few inches) Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 12, 2025 Share Posted February 12, 2025 1 hour ago, EmpireDrafting said: Would like to use a lidar point cloud for our Site Measures I feel like Chief has more capability in this regard than they're generally given credit for. We already can essentially import effective point cloud type data for site measurements using a number of different approaches and file formats including: Using the Import Drawing tool which allows for the Import of various dwg and dxf files (both of which can contain a whole slew of 2D vector data as well as elevation data) Using the Import Terrain Data tool which will allow for importing text based point data in a number of different file formats including txt, csv, xyz, dwg, dxf and others. This point data can include x, y, and z coordinates and can be used to automatically import and generate terrain elevation data. Using the Import GPS data tool which can also import both vector, point, and elevation data using the gpx file format The key to making it all work is really just exporting or converting the point cloud data into a usable file type which is oftentimes very easy, particularly considering some of the hardware/software combinations aren't technically producing a strictly defined "point cloud" anyway and are actually already just being natively generated in one of the aforementioned formats. Link to comment Share on other sites More sharing options...
Mayank_AmayaCAD Posted June 2, 2025 Share Posted June 2, 2025 We are a team of 29 and we provide Point cloud to Chief Architect modelling as a service at a very reasonable price. We accept point clouds from various scanners and matterport too. feel free to DM or email us at infoe@amayacad.com for details. Thank you Mayank J www.amayacad.com Link to comment Share on other sites More sharing options...
