Designer1 Posted October 30, 2019 Author Share Posted October 30, 2019 On 10/29/2019 at 12:03 PM, robdyck said: Of course there's a learning curve with PBR but I really don't have any 'setup' time anymore. Almost everything just got 'dropped in'. All my settings, and scene conditions are saved either in defaults or in my library. I didn't spend even 15 minutes on this; the only things not part of the actual plan are the plants, the car, the fence. Those 3 things took less than 2 minutes to add. Interestingly enough, I find PBR more predictable that RT. If I were being paid extra for a rendering for a home, I'd use RT or outsource to someone proficient with Lumion, or Twinmotion or Thea. However, in my market, my clients don't want to spend anything extra on 3d. That leaves me with a choice: I could tell them that I can't deliver any renderings without additional fees, or I can learn how to deliver (what I think are better than acceptable) renderings for virtually no additional time and exceed their expectations. And I'll point out that visualization is the claim, not photorealism. I'm in Alberta so photorealism would require a jacked up F350 and I haven't yet found a 3d model of a truck that truly meets my redneck expectations! Perhaps you should post an example of an exterior RT that one could be proud of and elaborate on the camera, lighting and RT settings you use. Expand Rob, Would you be willing to post some of your settings for those of us who haven't embarked on PBR yet? If not I understand as sometimes the secret recipes of chiefs tools are for each user to figure out. Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted October 30, 2019 Share Posted October 30, 2019 On 10/28/2019 at 11:29 PM, Designer1 said: Cheryl, what do you usually reduce the sun settings to before you begin the pbr? Expand I start with 350 lumens. My default interior lights are 50. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted October 30, 2019 Share Posted October 30, 2019 Sun = 1.5 Lux. There is one spot light behind the camera 50' from building face set @650 Lumens with shadows turned off. PBR DBX, Camera Expose = 1.0, Hue = 0, Saturation = 0, Brightness = 100. The PBR DBX above is my standard start settings. Sun is rarely more than 5 lux. My typical recessed spot light is between 30-50 Lumens. Point lights are usually less than 10 lumens. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted October 30, 2019 Share Posted October 30, 2019 Sun = 3 Lux, Recessed Spot Lights 15 Lumen. PBR DBX, Same as post above. Even with the sun at only 3 Lux, the direct light on the wall units is more than enough. If too bright it will obliterate all of the detail in it's path. 1 Link to comment Share on other sites More sharing options...
Designer1 Posted October 31, 2019 Author Share Posted October 31, 2019 Thanks Cheryl and Graham. Wow what beautiful renderings! Its nice to get some advice from the pros that have been using pbr for awhile just so us newbies on pbr can avoid some of the mishaps. It will be interesting to see quick results vs waiting for the raytrace. Im just happy the new raytrace engine back a few versions is so much better then in years past with the checkerboard background where you couldn't even see your image till it already ran for awhile. At least now you can stop and make adjustments before investing too much time. So this pbr thing will be even better. Thanks again for all the recommendations! Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 31, 2019 Share Posted October 31, 2019 On 10/31/2019 at 2:11 AM, Designer1 said: Thanks Cheryl and Graham. Wow what beautiful renderings! Its nice to get some advice from the pros that have been using pbr for awhile just so us newbies on pbr can avoid some of the mishaps. It will be interesting to see quick results vs waiting for the raytrace. Im just happy the new raytrace engine back a few versions is so much better then in years past with the checkerboard background where you couldn't even see your image till it already ran for awhile. At least now you can stop and make adjustments before investing too much time. So this pbr thing will be even better. Thanks again for all the recommendations! Expand You can always hire your Bay Area neighbor to do renderings for you and save you some time and maybe money 2 1 Link to comment Share on other sites More sharing options...
Designer1 Posted October 31, 2019 Author Share Posted October 31, 2019 On 10/31/2019 at 3:20 AM, Renerabbitt said: You can always hire your Bay Area neighbor to do renderings for you and save you some time and maybe money Expand Haha! Your probably right Rene! All us bay area chiefers should get together once in awhile and see what everyones specialty is in the industry so we have help and can refer people to each other. Your not far from San Jose at all! By the way... your rendering looks great! Did you do that in pbr or raytrace? Link to comment Share on other sites More sharing options...
Renerabbitt Posted October 31, 2019 Share Posted October 31, 2019 On 10/31/2019 at 8:32 AM, Designer1 said: Haha! Your probably right Rene! All us bay area chiefers should get together once in awhile and see what everyones specialty is in the industry so we have help and can refer people to each other. Your not far from San Jose at all! By the way... your rendering looks great! Did you do that in pbr or raytrace? Expand I would certainly be up for a meet and greet, great idea. I use a third party software that thrives on number of cores, gigs of RAM and number of CUDA cores..the reason for my ridiculous machine in my signature Link to comment Share on other sites More sharing options...
robdyck Posted October 31, 2019 Share Posted October 31, 2019 @RenerabbittThe espresso machine is plugged in?? Now you're taking it too far!! Or...not far enough; where's the crumbs on the floor and an open bag of bread on the counter? And there should be splash marks on that window behind the sink. Kidding of course. Nice work! 1 Link to comment Share on other sites More sharing options...
Rosco2017 Posted October 31, 2019 Share Posted October 31, 2019 On 10/28/2019 at 11:05 AM, robdyck said: As a matter of fact I do! Expand Hey, I'll take that bottle of wine when your done with it. Great looking project! Link to comment Share on other sites More sharing options...
robdyck Posted November 1, 2019 Share Posted November 1, 2019 On 10/31/2019 at 5:52 PM, Rosco2017 said: Hey, I'll take that bottle of wine when your done with it. Great looking project! Expand Thanks Ross! I appreciate that. Link to comment Share on other sites More sharing options...
Designer1 Posted November 2, 2019 Author Share Posted November 2, 2019 On 10/31/2019 at 2:15 PM, Renerabbitt said: I would certainly be up for a meet and greet, great idea. I use a third party software that thrives on number of cores, gigs of RAM and number of CUDA cores..the reason for my ridiculous machine in my signature Expand Yeah your computer sounds more like a space ship then a computer! So with all the high numbers does chief ever lag if you load a huge project or does it just hum along with zero lag? im going to upgrade my computer soon. I always buy a really big expensive one then wait a long while before replacing, so its getting close to the time im going to look for another new one. Link to comment Share on other sites More sharing options...
ChiefChris1 Posted November 3, 2019 Share Posted November 3, 2019 I used to use the "Final View" tool for quick images...and I had been happy with that. Is there something I need to do to process/activate a PBR after I set the camera defaults? Because when I open the camera view that is designated PBR, it doesn't look any different than a standard render/camera view. I am watching this video right now:https://www.chiefarchitect.com/videos/watch/2426/physically-based-rendering-technique.html Hopefully it will help.... edit.... after I watched that video clip. I still see no difference, not even when I adjust Camera Exposure. I must be missing something. My PBR camera view looks just like a standard camera view Link to comment Share on other sites More sharing options...
ChiefChris1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 12:08 AM, ChiefChris1 said: Expand I am not understanding...and I have to be missing something somewhere. But, I see no difference between my standard camera and PBR camera. There is no light (I have lights in the view). There is no sun. When I adjust the PBR view technique settings, I see no difference. Totally missing something somewhere....probably something that I have set as a default that I am not thinking about. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 12:08 AM, ChiefChris1 said: after I watched that video clip. I still see no difference, not even when I adjust Camera Exposure. I must be missing something. My PBR camera view looks just like a standard camera view Expand It sounds like you might not be switching the Camera Rendering Type to PBR from Standard after shooting the Camera? by Default the Camera is usually in STD view , then you can change the Rendering Type Link to comment Share on other sites More sharing options...
ChiefChris1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 12:37 AM, Kbird1 said: It sounds like you might not be switching the Camera Rendering Type to PBR from Standard after shooting the Camera? by Default the Camera is usually in STD view , then you can change the Rendering Type Expand Pretty sure I did that right. This is the ACTIVE CAMERA settings: And, right now, my PBR settings are the default. If I toggle back and forth from standard to PBR with the view open, I see nothing change. I can see obvious changes when I go to vector view, glass house etc. But I see no difference with standard & PBR. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 3, 2019 Share Posted November 3, 2019 Try .4 Exposure and turn on Improve Lighting Quality I also bump the Brightness to 70-80 for interiors ---a tip from Graham Link to comment Share on other sites More sharing options...
ChiefChris1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 1:09 AM, Kbird1 said: Try .4 Exposure and turn on Improve Lighting Quality I also bump the Brightness to 70-80 for interiors ---a tip from Graham Expand Thanks. Should I see something change in my display immediately? Because, that's not happening. OR, is there a "make final PBR" type tool? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 1:12 AM, ChiefChris1 said: Thanks. Should I see something change in my display immediately? Because, that's not happening. OR, is there a "make final PBR" type tool? Expand Not for the Default setting changes as they won't apply to existing cameras , you will need to open/shoot new cameras for the new Defaults, The Settings under Rendering Technique change pretty instantly though , these can also be setup in Defaults once you find settings you like, so when you switch to PBR from STD you are close to what you like. Link to comment Share on other sites More sharing options...
ChiefChris1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 1:17 AM, Kbird1 said: Not for the Default setting changes as they won't apply to existing cameras , you will need to open/shoot new cameras for the new Defaults Expand Perhaps that is what confused me...because in the Chief Demo video I watched, as she talked and changed settings (lighting, exposure etc) in the camera setting with the view open, it changed live. Link to comment Share on other sites More sharing options...
ChiefChris1 Posted November 3, 2019 Share Posted November 3, 2019 IN ANY CASE.... When I have a camera view...is there a "make this PBR view" tool? Or am I just saving a JPG of the display? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 1:28 AM, ChiefChris1 said: saving a JPG of the display Expand This....... I don't remember the "Make this...tool" in a recent version of Chief ? In the video She likely has the Defaults already setup , then she changes some settings in the Render Tech. which are live/instant, been a year since I watched that video so not quite sure what She did now.... M. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 1:12 AM, ChiefChris1 said: Thanks. Should I see something change in my display immediately? Because, that's not happening. OR, is there a "make final PBR" type tool? Expand Post your Plan if you are still having Issues so someone can have a look for you..... always the best advice since there are just too many variables. M. Link to comment Share on other sites More sharing options...
robdyck Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 1:27 AM, ChiefChris1 said: Perhaps that is what confused me...because in the Chief Demo video I watched, as she talked and changed settings (lighting, exposure etc) in the camera setting with the view open, it changed live. Expand Turn on shadows. Adjust sunlight. Boom! Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted November 3, 2019 Share Posted November 3, 2019 Global Illumination must be turned on in Preferences. Preferences, Render, under troubleshooting, turn on "use Global Illumination". Link to comment Share on other sites More sharing options...
