BrownTiger Posted November 2, 2019 Share Posted November 2, 2019 >How does one prevent getting multiple roof planes, every time I make a revision I get a new roof plane in the schedule. $tree = nil In the Ruby console will reset the collection. >Trying to get to the order as shown on the left of the attachment MacroRoof.txt >Lastly, how can one control the numbering order of roof planes. Any help is greatly appreciated. Don't have a clue. There is no roof scheduler. All planes are equal. All I can do is sort them from the largest to smallest. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 2, 2019 Share Posted November 2, 2019 1 hour ago, jonboy said: How does one prevent getting multiple roof planes, every time I make a revision I get a new roof plane in the schedule. Is there something one can change or add to the macro? Did you download the Macros I posted earlier in the Thread? import the clear_hash macro, it helps force a reset of the Roof Planes ( or room info if using that Macro too ) I have it in a text box on the Attic level but that maybe not necessary ? Mick. Link to comment Share on other sites More sharing options...
jonboy Posted November 3, 2019 Share Posted November 3, 2019 I would like to thank both of you, BT & Kbird for the help. I have one question, how does one change the fascia length from inches to feet - inches, thought it would safer to ask than to try messing the macro up. Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted November 3, 2019 Share Posted November 3, 2019 On 11/3/2019 at 8:46 AM, jonboy said: I would like to thank both of you, BT & Kbird for the help. I have one question, how does one change the fascia length from inches to feet - inches, thought it would safer to ask than to try messing the macro up. Thanks To do it roughly you can /12 (to get feet) and round it up (.ceil) to the nearest ft Not sure the items Fascia line is needed ??? Note the current formula ii for Eave Fascia only ...this will also show/add the Ridge for example on a Shed or mono slope roof Link to comment Share on other sites More sharing options...
jonboy Posted November 3, 2019 Share Posted November 3, 2019 Thanks for all your help only one thing left Still getting repeated roof planes ??? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 3, 2019 Share Posted November 3, 2019 Use the $tree = nil command in the Ruby console or what I found that works is Micks macro just placed in TMM and then all you seem to need to do is open the Text Schedule and press OK. Here it is posted separately from the package he posted earlier. Mick's clear_tree_Hash.txt Did you get my PM from the other day ? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 4, 2019 Share Posted November 4, 2019 1 hour ago, Chopsaw said: Here it is posted separately from the package he posted earlier. Mick's clear_tree_Hash.txt Well it not really mine, it was BrownTiger's info from an earlier post (it is a standard Ruby command to clear Hashes.... in this case $tree) I used Michael's Method to deploy it originally on the Attic Level but I too have found that Opening and Closing the Schedule causes the macro to be refreshed so there is no need to go up and down the levels although that works too. M. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 4, 2019 Share Posted November 4, 2019 Hello BT, I was able to follow your formatting to add additional properties to the resulting schedule. Is it possible to format so multiple columns can be totaled in the Text Schedule on the last line much like a stock CA schedule. Additional possibilities would be ridge vent, drip edge, valley flashing, etc. I tried several iterations but failed miserably. Link to comment Share on other sites More sharing options...
BrownTiger Posted November 4, 2019 Share Posted November 4, 2019 Like this MacroEaves.txt MacroLabel.txt This was for eaves fascia, you could also add up the " .gable_fascia_length" or ".ridge_vent_length", or even get the OSB (layers[1].material_data ) description: "OSB-Hrz" formatted_size: "48"x96"x1/2"" quantity: 14.25 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 4, 2019 Share Posted November 4, 2019 5 hours ago, BrownTiger said: Like this MacroEaves.txt MacroLabel.txt This was for eaves fascia, you could also add up the " .gable_fascia_length" or ".ridge_vent_length", or even get the OSB (layers[1].material_data ) description: "OSB-Hrz" formatted_size: "48"x96"x1/2"" quantity: 14.25 Thanks for the Help BT , much appreciated Mick. Link to comment Share on other sites More sharing options...
jonboy Posted November 4, 2019 Share Posted November 4, 2019 Thanks guys for all the help BT that would be great to have all that information in schedule, just not sure I want to attempt that. Jon Link to comment Share on other sites More sharing options...
Chopsaw Posted December 20, 2019 Share Posted December 20, 2019 On 11/4/2019 at 9:28 AM, BrownTiger said: Like this MacroEaves.txt MacroLabel.txt This was for eaves fascia, you could also add up the " .gable_fascia_length" or ".ridge_vent_length", or even get the OSB (layers[1].material_data ) description: "OSB-Hrz" formatted_size: "48"x96"x1/2"" quantity: 14.25 Hello: Brown Tiger I have made good progress with your last example. The gable fascia and ridge vent work great. However I seem to be missing something in how to format the "OSB (layers[1].material_data )" to be able to retrieve and display the NVPubisher properties of description, formatted_size,quantity, etc. If you have a moment could you possibly write that example into your previously posted MacroLabel.txt example for us. Many Thanks, Chopsaw Link to comment Share on other sites More sharing options...
BrownTiger Posted December 20, 2019 Share Posted December 20, 2019 5 hours ago, Chopsaw said: Hello: Brown Tiger I have made good progress with your last example. The gable fascia and ridge vent work great. However I seem to be missing something in how to format the "OSB (layers[1].material_data )" to be able to retrieve and display the NVPubisher properties of description, formatted_size,quantity, etc. If you have a moment could you possibly write that example into your previously posted MacroLabel.txt example for us. Many Thanks, Chopsaw You are working with NVCollection not an Array... >obj.layers[1].material_data.description <- wrong Get your object material = obj.layers.to_a[1].material_data to_a(*args) → array Returns an array containing the items in enum See: https://ruby-doc.org/core-2.6.5/Enumerable.html#method-i-to_a Now material.description, material.formatted_size, material.quantity should all be a valid methods. Now sure if you wanted to collect it or just display.... macro: labelRoofPlane [don't forget the Evaluate checkbox] MacroLabel (1).txt 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 20, 2019 Share Posted December 20, 2019 That works, Thank You ! On my way again. Collect Display Calculate. Having fun now. Link to comment Share on other sites More sharing options...
rgardner Posted January 2, 2020 Share Posted January 2, 2020 I know this is a post that is way over my head at this time but I have been reading on it and more all morning and am still having some issues. I am using the great macro all you experts hashed out: == referenced ? obj = referenced : obj = owner if $tree.nil? $tree = Hash.new { |hash, key| hash[key] = {} } end id="p" + obj.object_id.to_s pitch = obj.automatic_label area = (obj.surface_area).ceil areasq = ( obj.framing_area / 100.0 ).ceil slope = obj.angle.round(2) #slope = (Math.atan2(obj.pitch,12.0)*180.0/Math::PI).round(2) ALT Slope Formula #unless $tree['roofplanes'].has_value?(id) items = Hash.new() items['roof_plane']=id items['pitch']=pitch items['area']=area items['areasq']=areasq $tree['roofplanes'][id]=items #end indx = $tree['roofplanes'].keys.find_index(id) result = "Roof Plane No# : " + (indx+1).to_s + "\n" result += "Roof Area Sqft : " + area.to_s + " sqft" + "\n" result += "Roof Area Total Sqs : " + areasq.to_s + " sq" + "\n" result += "Roof Pitch : " + pitch + "\n" result += "Slope Angle : " + slope.to_s + "°\n" result == It is working as intended but I was hoping to have a similar macro for one of my builders who doesn't want to see as much info. I have tried to copy and create a similar macro and only get the dreaded error. If any of you macro gurus have a second and could help out I would be as always ever grateful for the assistance. This builder wants to see: Roof Area Sq. Ft. (as is in the current macro) Roof Area Total Sqs. (as is in the current macro) Roof Pitch (as is in the current macro) I know this would just be deleting parts of the macro to remove the plane No# and slope angle. But what I have tried to do seems to get an error so I am assuming instead of deleting something I need to change it???? Side note I have not been able to figure out the arrow placement issue. I can make it different size and I can add blank lines before the macro to get the arrow out of the middle of the text and not being seen or looking jumbled but is there a way to get the macro to have the arrow right after the pitch line??? TIA for anyone who takes their valuable time with this and helps me and anyone else who can benefit with this as we try to learn the awesomeness of macros! Link to comment Share on other sites More sharing options...
Chopsaw Posted January 2, 2020 Share Posted January 2, 2020 Is this what you are after Ryan ? Just the roof plane label and no tally or schedule required ? Link to comment Share on other sites More sharing options...
rgardner Posted January 3, 2020 Share Posted January 3, 2020 1 hour ago, Chopsaw said: Is this what you are after Ryan ? Just the roof plane label and no tally or schedule required ? Exactly and with the arrow below the roof pitch like that. How did you do it? Link to comment Share on other sites More sharing options...
Chopsaw Posted January 3, 2020 Share Posted January 3, 2020 Take a look and enjoy. Roof Plane Label for Ryan.json 1 Link to comment Share on other sites More sharing options...
DavidKorpela Posted March 20, 2020 Share Posted March 20, 2020 On 1/2/2020 at 4:52 PM, Chopsaw said: Take a look and enjoy. Roof Plane Label for Ryan.json I've been trying to get this roof label information on how to create this, but when I click on the link it wont open anything and tells me that I have to have an app to open it with and I don't have any idea what app I need. Is there a way you can get the information to me? If you can email I'm davidleedesign@comcast.net thanks Link to comment Share on other sites More sharing options...
Chopsaw Posted March 20, 2020 Share Posted March 20, 2020 5 minutes ago, DavidKorpela said: I've been trying to get this roof label information on how to create this, but when I click on the link it wont open anything and tells me that I have to have an app to open it with and I don't have any idea what app I need. Is there a way you can get the information to me? If you can email I'm davidleedesign@comcast.net thanks Hello David, The file that I posted works with Chief Architect Premier. Link to comment Share on other sites More sharing options...
