Ruby Macros
lavorhaynie
Anyone out there offer Ruby services for $?  I need a fairly simple macro created.
I need a label for my layout files that will display the path of the layout file (%file%), truncating the first nn characters.
i.e.  d:\Users\username\DesignWork\CAX11\Builders\Builder_1\Standard_Plans\Plan_1
       with nn=43 would display as:
-or-
Can this be done in X11 without writing a macro?
Thanks much!
Expand
No, but it's fairly simple to do.
There are 2 Ruby Attributes of a Layout Box that can be used:
  • referenced_full_filename  -  same as %file%
  • referenced _filename  -  just the name of the file that was sent to layout.
It would actually be better to know what set of letters you want to eliminate rather than a specific number of characters.
For example:
  • d:\Users\username\DesignWork\CAX11\Builders\
where you provide the actual username.
Expand
How would that look Joe if you just wanted to hide the directory and /Users/Username/ and maybe a file or two ?
Or are you wanting the exact characters ?
@Alaskan_Son contacted me and wrote a macro that pulls the path string I need.  Did a great job at a very reasonable price. Thank you @Alaskan_Son!
Joe, I set up your suggestion and found that it works well too.  I do have a question for you, or anyone that might know the answer... how do you get the Ruby Attributes of a Layout Box that can be used?
Actual path (filename not included):
C:\Users\zbook17g3\OneDrive\_Business\DesignsByLaVor\_WorkX11\_Builders\CH - Compass\Clients\Working\Hancock - Hardin
Your suggestion from above:
        CH - Compass/Clients/Working/Hancock - Hardin/Hardin
I would like to have:
Thanks!
I have a macro that will show (in the Ruby Console) all the attributes for any selected object.
Here's the list for a typical Layout Box:
automatic_label ------------ "Graph Schedule Section/Elevation" ------------------------------------------------------------------------------------ String
box_scale ------------------ "1/4 in = 1 ft" ------------------------------------------------------------------------------------------------------- String
drawing_group -------------- 1 --------------------------------------------------------------------------------------------------------------------- Integer
floor_number --------------- 1 --------------------------------------------------------------------------------------------------------------------- Integer
height --------------------- 5.390048486681028 ----------------------------------------------------------------------------------------------------- Float
layer ---------------------- arch-d_layout_box_borders --------------------------------------------------------------------------------------------- Symbol
layer_line_color ----------- 255 ------------------------------------------------------------------------------------------------------------------- Integer
layer_line_style ----------- 0 --------------------------------------------------------------------------------------------------------------------- Integer
layer_line_weight ---------- 1 --------------------------------------------------------------------------------------------------------------------- Integer
layer_set ------------------ "Arch-D Print" -------------------------------------------------------------------------------------------------------- String
layer_text_style ----------- "HIDDEN" -------------------------------------------------------------------------------------------------------------- String
line_style ----------------- solid ----------------------------------------------------------------------------------------------------------------- Symbol
line_weight ---------------- 1 --------------------------------------------------------------------------------------------------------------------- Integer
object_type ---------------- layout_box ------------------------------------------------------------------------------------------------------------ Symbol
referenced_filename -------- "Jason Bales Residence - Phase 1" ------------------------------------------------------------------------------------- String
referenced_full_filename --- "D:/Dropbox/Chief Architect Projects/X11/Jason Bales Residence - Phase 1/Plan/Jason Bales Residence - Phase 1.plan" --- String
referenced_layer_set ------- "All On Set" ---------------------------------------------------------------------------------------------------------- String
width ---------------------- 3.6485143922610597 ---------------------------------------------------------------------------------------------------- Float
  On 10/14/2019 at 2:44 AM, lavorhaynie said:
would like to have:
Expand
nstart = 43
nlast = referenced_full_filename.length-1
result = referenced_full_filename[nstart,nlast]
result = result.gsub(".plan","")
result = result.gsub("/Hardin","")
explanation:
  line 3 sets the result to the characters starting at the 43rd character and ending at the last character
  line 4 strips all instances of ".plan" from the result
  line 5 strips all instances of "/Hardin" from the result
Expand
The actual characters would be required
  - or the number of "/" characters
  - or maybe if you just want to eliminate everything after the last "/".
There are several possibilities.  The macro can become more complex - actually just longer - depending on what rules you want to follow.
Ruby is mostly about manipulating data and performing calculations.  This case is basic manipulation of a text string - which is very much just an array of characters.
Expand
I was just looking at the macro you just wrote for LaVor and realized that it will only work for one particular file.
Is there a way to take his example of :
C:\Users\zbook17g3\OneDrive\_Business\DesignsByLaVor\_WorkX11\_Builders\CH - Compass\Clients\Working\Hancock - Hardin\Hardin.plan
Then write a macro that effectively eliminates everything before the 8th instance of "\" and after the 12th instance.
Producing the result of :
Then this would work for every project unless there was a change in the structure of the file path and then the macro could easily be rewritten or copied and edited ?
Expand
Yes.  That’s essentially the method I utilized.  In a nutshell, my method for this particular use case was to first convert the file path to a string, then to break that string up into an array of values to represent drive, directory, subdirectories, and file, and then to display only the first 3 of the last 4 values in the array.
Expand
Ok that sounds much more logical.  Thank You.
I guess what you are saying is that useful macro's cost money.
Expand
...or at the least, valuable time and expertise. The first of which you can of course spend freely...in order to arrive at the second if you should so choose to do so.
Or, if your time is valuable enough to you, yes, you can just pay one of us (with money) to set something up for you or perhaps to coach you so you can start writing your own.
Expand
Sure, but a better method would be to use:
  • result = referenced_full_filename.rpartition("_Builders/")
  • result = result[2].rpartition("/")
  • result = result[0]
This way you only have to know that you want to eliminate everything up-to and including "_Builders/" and everything after the last "/".
Note that I'm using the "/" instead of the "\" because that's what Chief uses in the referenced_full_filename attribute.
Expand
Thanks Joe,  I will give that a try.
  On 10/14/2019 at 5:54 PM, Joe_Carrick said:
It might work as just a one line macro.  I'm not sure because sometimes Ruby doesn't like too many methods on a single line.  IAE you can try it:
  • result = referenced_full_filename.rpartition("_Builders/")[2].rpartition("/")[0]
Expand
Yes that works ok with Chief.   Thanks B)
