WoodlandDesign Posted August 12, 2019 Share Posted August 12, 2019 Does anyone know if CA can create a basic, non-detailed 'sketch' of a complete plan? See my attached sample. I would like to provide clients an overly simplified floor plan without the technical jargon so it's brief enough to share without giving away construction details. This one is created using Sketchup. I don't want to have to draw up another floor plan. I just want to 'convert' that which was created. I hope that makes sense. Thanks in advance. Link to comment Share on other sites More sharing options...
SNestor Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 4:07 PM, WoodlandDesign said: Does anyone know if CA can create a basic, non-detailed 'sketch' of a complete plan? See my attached sample. I would like to provide clients an overly simplified floor plan without the technical jargon so it's brief enough to share without giving away construction details. This one is created using Sketchup. I don't want to have to draw up another floor plan. I just want to 'convert' that which was created. I hope that makes sense. Thanks in advance. Expand Just Create a new Annotation Set and Layerset...it's that simple. Layersets control what is displayed...Annotation Sets control the color, size, font, of all text objects. 1 Link to comment Share on other sites More sharing options...
JJohnson Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 4:09 PM, SNestor said: Just Create a new Annotation Set and Layerset...it's that simple. Layersets control what is displayed...Annotation Sets control the color, size, font, of all text objects. Expand Yes. Create another layer set and call it Sketch Set, adjust layers to suit. Link to comment Share on other sites More sharing options...
WoodlandDesign Posted August 12, 2019 Author Share Posted August 12, 2019 By doing this can lines be adjusted to appear like line drawings? Link to comment Share on other sites More sharing options...
robdyck Posted August 12, 2019 Share Posted August 12, 2019 Yes. This one took me 20 seconds. It's an orthographic floor overview, watercolor, line drawing on. Simple method would be to send it to layout behind a layerset showing only the room labels. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 4:21 PM, WoodlandDesign said: By doing this can lines be adjusted to appear like line drawings? Expand tricky but doable, you need yo do a orthographic floor overview using the line drawing technique Link to comment Share on other sites More sharing options...
robdyck Posted August 12, 2019 Share Posted August 12, 2019 Here's on with more squiggle, blurrier paint, and the top cut off at 78" . Link to comment Share on other sites More sharing options...
Kbird1 Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 4:32 PM, Renerabbitt said: tricky but doable, you need yo do a orthographic floor overview using the line drawing technique Expand I do it like Rob does, as well, when needed , it's not that bad once you open the Ortho Floor Camera, as you can go to 3D>View Direction>Top View for a perfect Top down view, then open the rendering Tech. an adjust the squiggle , extend etc as needed. M. Link to comment Share on other sites More sharing options...
Renerabbitt Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 4:41 PM, Kbird1 said: I do it like Rob does, as well, when needed , it's not that bad once you open the Ortho Floor Camera, as you can go to 3D>View Direction>Top View for a perfect Top down view, then open the rendering Tech. an adjust the squiggle , extend etc as needed. Expand The part that was tricky I didnt clarify...speaking about adding dimensions and annotations over a rendering gets tricky Link to comment Share on other sites More sharing options...
Kbird1 Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 4:43 PM, Renerabbitt said: The part that was tricky I didnt clarify...speaking about adding dimensions and annotations over a rendering gets tricky Expand Ahhhh, I wasn't thinking about Dims as Doug didn't show them in his example , I thought that was the kind of information he was trying to remove actually. M. Link to comment Share on other sites More sharing options...
SNestor Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 4:07 PM, WoodlandDesign said: Does anyone know if CA can create a basic, non-detailed 'sketch' of a complete plan? See my attached sample. I would like to provide clients an overly simplified floor plan without the technical jargon so it's brief enough to share without giving away construction details. This one is created using Sketchup. I don't want to have to draw up another floor plan. I just want to 'convert' that which was created. I hope that makes sense. Thanks in advance. Expand This view (see picture) was created by using the 3D Floor Overview camera, then selecting 3D/View Direction/Top View; Then I used the cross section slider to cut down into the view...then I applied the "line drawing" technique. Yes...placing room labels and sizes...and dimensions gets a little complicated. I added text to this screen shot using Snagit...so, that's a possibilty. Link to comment Share on other sites More sharing options...
WoodlandDesign Posted August 12, 2019 Author Share Posted August 12, 2019 Thanks everyone. It's clear there are several ways to do this which, in their own way, accomplish the intended goals. I will experiment with the different techniques to create a standardized method which I can use repeatedly. Link to comment Share on other sites More sharing options...
robdyck Posted August 12, 2019 Share Posted August 12, 2019 On 8/12/2019 at 6:16 PM, SNestor said: This view (see picture) was created by using the 3D Floor Overview camera, then selecting 3D/View Direction/Top View; Then I used the cross section slider to cut down into the view...then I applied the "line drawing" technique. Yes...placing room labels and sizes...and dimensions gets a little complicated. I added text to this screen shot using Snagit...so, that's a possibilty. Expand It's not complicated. Send the ortho overview to layout, send a floorplan to layout. Using draw order tools ensure the floorplan is on top of the overview. Set layers as desired. No mess, no fuss, repeatable, automatically updates. 1 Link to comment Share on other sites More sharing options...
