EsteeChief Posted June 20, 2019 Share Posted June 20, 2019 Hello, Anyone knows how to shorten the cells of a schedule ? The program created one too long to fit into the layout... Maybe there is manual way to create one ? Thanks... Link to comment Share on other sites More sharing options...
Chopsaw Posted June 20, 2019 Share Posted June 20, 2019 Have you tried making the Symbol column narrower ? Link to comment Share on other sites More sharing options...
chief58 Posted June 20, 2019 Share Posted June 20, 2019 What I would do is make a copy of the plan on the layout page, then one of the copies select it and select the scale tool and make it not to scale then you can move the selected boundy and move them until only the that schedule is showing and then up the top icon select the resize icon and adjust to fit the only thing that happens is it is not to scale Link to comment Share on other sites More sharing options...
EsteeChief Posted June 20, 2019 Author Share Posted June 20, 2019 yes I did... I'm working on it for a couple of hours.. nothing works. I talked to support and they didn't know either. Im so surprised that such a basic thing is so complicated and unsolvable... Thanks though... Link to comment Share on other sites More sharing options...
chief58 Posted June 20, 2019 Share Posted June 20, 2019 1 minute ago, EsteeChief said: yes I did... I'm working on it for a couple of hours.. nothing works. I talked to support and they didn't know either. Im so surprised that such a basic thing is so complicated and unsolvable... Thanks though... what version are you using and if you send me the file I will work on it for you or post it here Link to comment Share on other sites More sharing options...
EsteeChief Posted June 20, 2019 Author Share Posted June 20, 2019 Interiors X11 Link to comment Share on other sites More sharing options...
EsteeChief Posted June 20, 2019 Author Share Posted June 20, 2019 Here you are and Thanks Admirals_8_May_2019 Electrical.layout Link to comment Share on other sites More sharing options...
Chopsaw Posted June 20, 2019 Share Posted June 20, 2019 You will also need to post the plan file the layout file references. P.S. Your scale is 3/16 not 3/8 Link to comment Share on other sites More sharing options...
EsteeChief Posted June 20, 2019 Author Share Posted June 20, 2019 Yes, I forgot to change it.. just did thanks Link to comment Share on other sites More sharing options...
glennw Posted June 20, 2019 Share Posted June 20, 2019 I know how to easily resize the schedule in both directions at once if that helps. Select the schedule, shift select the symbol again. Grab the small top centre grip and drag it down. Link to comment Share on other sites More sharing options...
EsteeChief Posted June 20, 2019 Author Share Posted June 20, 2019 Thanks, but it shrinks everything and unable to read.. Link to comment Share on other sites More sharing options...
chief58 Posted June 20, 2019 Share Posted June 20, 2019 Estee when I downloaded your layout I didn't get the file so I wasn't able to do anything with it Link to comment Share on other sites More sharing options...
EsteeChief Posted June 20, 2019 Author Share Posted June 20, 2019 Thank you for your efforts... I just purchased this program, so my files are a mess... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 20, 2019 Share Posted June 20, 2019 You should be able to limit the Schedule(s) to specific Rooms. This will make your Schedule(s) shorter - but you will need multiple Schedules. ps: Training is pretty much a requirement for a program of this complexity. Link to comment Share on other sites More sharing options...
EsteeChief Posted June 20, 2019 Author Share Posted June 20, 2019 I do have only this schedule though....thanks Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 20, 2019 Share Posted June 20, 2019 1 hour ago, EsteeChief said: I do have only this schedule though....thanks When you open the Schedule dbx do you not have an option to "Include Items only from Rooms:" ? Link to comment Share on other sites More sharing options...
Dermot Posted June 20, 2019 Share Posted June 20, 2019 The best way to make this schedule smaller is to make the row height smaller. To reduce the row height, you need to reduce the column width used for the preview image. You can not reduce it smaller then the column header so you may also need to rename the column to something shorter to get a smallest size. You could also create multiple schedules showing different objects if you wanted to reduce the size. You can filter a schedule by floor, by room, or by object type. In your case, you could make 3 separate schedules, one each for outlets, switches, and lights. Unfortunately, there is no way to arbitrarily split a schedule into multiple schedules. Link to comment Share on other sites More sharing options...
EsteeChief Posted June 21, 2019 Author Share Posted June 21, 2019 I will try that !! Link to comment Share on other sites More sharing options...
