brianhf Posted May 14, 2019 Share Posted May 14, 2019 Hello everyone. I am having a problem creating a store front type window/door installation. Chief will not allow me to arrange a door with a window directly above it where they are touching, as would be normal in a store front installation. I have tried changing the spacing between windows to "0" and removed all headers, cripples, etc. There is still brick displayed where it doesn't belong. Image and file attached.Ainsworth plan 8.plan thanks for any input. Brian. Link to comment Share on other sites More sharing options...
DG1949 Posted May 14, 2019 Share Posted May 14, 2019 Hi, You might have a default door header that's getting in the way. Going to "Framing" in the Door DBX, uncheck default header and un-click "include header". Link to comment Share on other sites More sharing options...
ShaneK Posted May 14, 2019 Share Posted May 14, 2019 You must of made some changes, I see a different view than you posted Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 14, 2019 Share Posted May 14, 2019 Like this? All I did was pull the bottom of the window down. Link to comment Share on other sites More sharing options...
brianhf Posted May 14, 2019 Author Share Posted May 14, 2019 Yes, window and door like that, but no brick between. thanks, Brian. Link to comment Share on other sites More sharing options...
MarkMc Posted May 14, 2019 Share Posted May 14, 2019 set window default minimum mull distance to 0", check hgt off floor of door (92" here), open window dbx- adjust height of window and height off floor. I did not mull them. You could but that brings in other issues. Ainsworth plan N.plan Link to comment Share on other sites More sharing options...
MarkMc Posted May 14, 2019 Share Posted May 14, 2019 It also works just moving the window with the DBX and not changing the mulling distance. Link to comment Share on other sites More sharing options...
brianhf Posted May 14, 2019 Author Share Posted May 14, 2019 Mark. Thanks for you input. I'll give it a shot. Brian Link to comment Share on other sites More sharing options...
ACADuser Posted May 15, 2019 Share Posted May 15, 2019 This is what I get by changing all the frame to 2.5" and sash to 0.1" Use Ctrl Drag to move the window frames over the door frames Link to comment Share on other sites More sharing options...
brianhf Posted May 15, 2019 Author Share Posted May 15, 2019 That looks exactly right!! Thanks for your input. Appreciate. Brian. Link to comment Share on other sites More sharing options...
ACADuser Posted May 15, 2019 Share Posted May 15, 2019 The only drawback is that you can not Mull overlapping windows & doors. I've tried side frames at 1.25" but you can not control one side separately. Link to comment Share on other sites More sharing options...
