plans
decorators3
…..Hi
I created a floorplan with finished kitchen and en suite and saved it SAVE AS...… - however I don't know where I saved it and when I go into my Program it does not show up in recent files because I'm working  on several at the moment. How do I find files that are not showing in the program under  "Open Recent Files"
Thanks
Levina
8 hours ago, justmejerry said:
If you open preferences under new plans at the bottom it tells you where your new plans and save as plans are stored. Unless you specifically changed the directory during the save this is where it should be.
Nice catch....Even if you have Use Last Folder Checked... the line below still tells you were the last save was made... it will even let you Browse there by checking Use this Folder
Easiest way as mentioned is to do another Save as and see where it want to save again this time.....
