ShaneK Posted December 17, 2018 Share Posted December 17, 2018 This project is sold and done BUT I had a strange thing happen while printing to PDF. You can see in layout preview that floor joists are correct and in the open cross section they are correct. When I print to PDF you the floor joists are not correct in either cross sections. Both files are attached for anyone interested. I tried printing Chief PDF and PDF-Xchange both have same result. Vernell Phipps.layout Saginaw_Project_12-02-18.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted December 18, 2018 Share Posted December 18, 2018 It looks pretty bad Shane. I tried all the tricks I could remember and made it worse. See below for new camera sent to layout and failure in print preview. Link to comment Share on other sites More sharing options...
MPDesign Posted December 18, 2018 Share Posted December 18, 2018 Hi Shane I was able to figure out that if the views are changed to plot lines with color fill it printed correctly. Chief to pdf printer. Vernell Phipps-sht6-print4.pdf 1 Link to comment Share on other sites More sharing options...
ShaneK Posted December 18, 2018 Author Share Posted December 18, 2018 Thank you Michael for trouble shooting it and that worked but should not have to do that, I made it behave in a different manner to get project wrapped up. I will do more looking into it or send it in. Link to comment Share on other sites More sharing options...
MPDesign Posted December 18, 2018 Share Posted December 18, 2018 Your welcome, I stopped using live views to layout a will back after having similar problems. Don't recall if I sent it in to tech. Link to comment Share on other sites More sharing options...
Doug_N Posted December 18, 2018 Share Posted December 18, 2018 Here is something to watch. Keep the view on the layout inside the boundary of the drawing page area. If you don't clip the viewport the PDF will go nuts. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 19, 2018 Share Posted December 19, 2018 4 hours ago, Doug_N said: Keep the view on the layout inside the boundary of the drawing page area. If you don't clip the viewport the PDF will go nuts. Interesting observation Doug. Were you able to correct the problem in Shane's PDF with that technique ? Link to comment Share on other sites More sharing options...
ShaneK Posted December 19, 2018 Author Share Posted December 19, 2018 @ Doug Norton,,,,, I do keep it within boundaries of layout sheet. I'm sending it in soon, lol. Thanks guys for peaking at it. Link to comment Share on other sites More sharing options...
ShaneK Posted December 19, 2018 Author Share Posted December 19, 2018 After some trial and error I find that if cross section view changed to "vector" view and sent to layout it is correct and will stay updated too. Still not the correct behavior but,,,,,,, it works. This is 1st time I have ever sent cross sections to layout as a vector view, I have always went with standard view. Link to comment Share on other sites More sharing options...
Doug_N Posted December 20, 2018 Share Posted December 20, 2018 On 12/18/2018 at 8:03 PM, Chopsaw said: Interesting observation Doug. Were you able to correct the problem in Shane's PDF with that technique ? Actually, I have been so busy trying to get projects pushed out ahead of Christmas I didn't try. sorry to say. My bad. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 21, 2018 Share Posted December 21, 2018 Just one man's opinion here, but I would stop using Live View if I was you and switch to Plot Lines. There are multiple reasons for this including but not limited to: -You have much more robust control over how the various edge and pattern lines are displayed -The lines are crisper and more consistent -The Edit Layout Lines tool becomes available -The views look like they WILL look while you're working on them. In my opinion, the standard views in the example above don't actually look as nice as vector views either. They feel a little less professional to me. Just my 2 cents. Link to comment Share on other sites More sharing options...
