ChiefuserMathews Posted November 20, 2018 Share Posted November 20, 2018 I had the floor area (by default it displays as "Living" label on my plan. For some reason I deleted it. How to get it back? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 20, 2018 Share Posted November 20, 2018 Run Plan Check Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted November 20, 2018 Author Share Posted November 20, 2018 I did still its not displaying the living area SF info Link to comment Share on other sites More sharing options...
parkwest Posted November 20, 2018 Share Posted November 20, 2018 Make sure that layer is on in current view. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted November 20, 2018 Author Share Posted November 20, 2018 Please note I have deleted it for some reason. Now I would like to bring it back. I turned on all on set (layer), still I can't get it back Link to comment Share on other sites More sharing options...
Kbird1 Posted November 20, 2018 Share Posted November 20, 2018 Defaults>Plan>Living area Checkbox at the bottom assuming you just turned it off.... Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted November 20, 2018 Author Share Posted November 20, 2018 yes its checked in. like i said i deleted for some reason. now how to get it back, because i wanted to know what is the current floor area Link to comment Share on other sites More sharing options...
Kbird1 Posted November 20, 2018 Share Posted November 20, 2018 17 minutes ago, ChiefuserMathews said: yes its checked in. like i said i deleted for some reason. now how to get it back, because i wanted to know what is the current floor area That is what Joe mentioned above ....running the Plan Check should bring it back... Tools>Checks>PlanCheck just ok your way through it and the last one should bring it back ....does here.... Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted November 20, 2018 Author Share Posted November 20, 2018 yes i did that for some reason it is not displaying that label. I am learning as i go. . this is what i get when i run the plan check Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted November 20, 2018 Author Share Posted November 20, 2018 If that is not possible, how to recalculate the floor area? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 20, 2018 Share Posted November 20, 2018 post the plan Link to comment Share on other sites More sharing options...
Kbird1 Posted November 20, 2018 Share Posted November 20, 2018 If Room Labels are on and you don't see it then post the plan so someone can have a look.... you did zoom out right ? incase you moved it down or to the side? M. Link to comment Share on other sites More sharing options...
rwdozier Posted November 20, 2018 Share Posted November 20, 2018 In X5, I can delete the Living Area Room Label, save and reopen the plan to verify the Living Area Room Label is still gone. I can then break an exterior wall to open it or just pull back a corner connection. As soon as you open up the exterior wall, the Living Area Room Label reappears. Link to comment Share on other sites More sharing options...
MikeAnderson Posted November 20, 2018 Share Posted November 20, 2018 Double click on the selection arrow at the top left of toolbar, brings up "General Plan Defaults" Make sure that the check box at the bottom (Show Living Area Label) is checked. Link to comment Share on other sites More sharing options...
Kbird1 Posted November 21, 2018 Share Posted November 21, 2018 2 hours ago, solver said: Use Edit>Edit Area Marquee around the entire plan, Cut, then Paste/Hold Position. If you try this turn on the All On Set 1st ( and make sure every layer has the blue check mark) then paste into a new Plan. At least in my experience recently, it only copies things that were "visible" despite there also being a Visible edit area option. M. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted November 21, 2018 Author Share Posted November 21, 2018 Thank you all for your response. Eric's reply did work. Thanks again. Very productive forum Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted November 21, 2018 Author Share Posted November 21, 2018 2 hours ago, solver said: Use Edit>Edit Area Marquee around the entire plan, Cut, then Paste/Hold Position. this option worked. thanks Eric and to all who have contributed Link to comment Share on other sites More sharing options...
lbuttery Posted November 21, 2018 Share Posted November 21, 2018 Tools>Checks>PlanCheck This "super secret" fix has got to go talk about not being "user friendly" how would anyone know this - without knowing ??? Lew Link to comment Share on other sites More sharing options...
Kbird1 Posted November 21, 2018 Share Posted November 21, 2018 1 hour ago, lbuttery said: Tools>Checks>PlanCheck A side-effect of this for me yesterday was it turned back on ALL Room Labels ( I have them off when "working") even though they were set not to Display in the ALDO, so I had to remove them Manually again. Can't remember if I was in X9 or X10 when I tried it to confirm Joe's Post though. M. Link to comment Share on other sites More sharing options...
