tinting glass?
Larry_Sweeney
Larry,
Click on the Adjust the Material Definition Button > With that loaded, click on the Material that you want to change > Under the General Tab you'll find the Color for the Material. You may have to experiment a bit. I find that a deeply shaded blue-green works well for me. HTH
Eric & Cheryl .................................Thanks for the quick responses. Eric, your answer was correct, but Cheryl's answer was a little clearer for me. I didn't realize (or at some point I forgot :)) that darkening the color would "tint" the glass. Thanks again and have a great day.
Chief's Library also comes with Green , Grey , Milk (white) ,Tempered ( green tinge ), and Laminated ( Bluish) ready made
Some manufacturers Like Marvin also have Glass under Options.
  • 5 years later...
Usually best to start new threads for new topics.
The short answer is that it all depends on how the door symbol you are using was set up.  If the symbol has a separate material for the panel then from the frame, then you should be able to assign a glass material to it.  If you can't find one that works, you could always build your own.  Here is a training video that covers the basics:
https://www.chiefarchitect.com/support/article/KB-01808/creating-a-custom-door.html
  • Like 2
  • 1 year later...
Way off topic here, but this post was a blast from the past. Cheryl was an amazing person and taught me so much when I first started out on my own. I enjoyed our chats and collaboration on plans we sent back and forth and her vast knowledge of kitchen design. She will go down as one of the few who really made an impact on my Chief Architect journey. You are truly missed Cheryl.
  • Like 4
