wolfrem68 Posted August 16, 2018 Share Posted August 16, 2018 I have an older version of Chief Architect # 7.0. I used it when I was in construction in New Mexico. When I purchased the program I unfortunately asked for the version with the password instead of the dongle. My questions are # 1- is there any way to get an access into the program. I still have the serial number, CD key, user code and pass word from way back. Any suggestions? Question # 2 - I have a 36 inch HP 650 color plotter that was used with a desk top and has the 21 pin cable. Anyway to connect my laptop to the plotter now? Any help would be truly appreciated. Link to comment Share on other sites More sharing options...
wolfrem68 Posted August 16, 2018 Author Share Posted August 16, 2018 thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted August 16, 2018 Share Posted August 16, 2018 On 8/16/2018 at 7:41 PM, wolfrem68 said: I have an older version of Chief Architect # 7.0. I used it when I was in construction in New Mexico. When I purchased the program I unfortunately asked for the version with the password instead of the dongle. My questions are # 1- is there any way to get an access into the program. I still have the serial number, CD key, user code and pass word from way back. Any suggestions? Question # 2 - I have a 36 inch HP 650 color plotter that was used with a desk top and has the 21 pin cable. Anyway to connect my laptop to the plotter now? Any help would be truly appreciated. Expand If you have the PW etc what is the Issue ? some of the Older Versions my not run on Win10 , for one that old you may need XP or Perhaps Win7? Do you mean a 25pin DB25 Printer Cable perhaps? there are USB to DB25 Converter Cables available eg : https://www.newegg.com/Product/Product.aspx?Item=N82E16812200160 Link to comment Share on other sites More sharing options...
lbuttery Posted August 16, 2018 Share Posted August 16, 2018 Hi: ver 7 is literally an antique you might want to consider a newer product https://www.homedesignersoftware.com/ the cost can be applied in full towards upgrade to newest Chief if you later decide to go that route Lew Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 16, 2018 Share Posted August 16, 2018 I have version 7 but on a separate hard drive that runs Windows XP. I do not think it will run at all in Vista, Windows 7 or 10. You would be better served to purchase Home Designer Professional for $495.00 which is designed to run on Windows 10 64 bit. DJP Link to comment Share on other sites More sharing options...
tommy1 Posted August 17, 2018 Share Posted August 17, 2018 I agree with David. That would be your best option if not purchasing Premier. However, I don't believe you'll be able to open that V7 file in HD Prodessional. You might need someone to bring it forward for you. Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 17, 2018 Share Posted August 17, 2018 In terms of Version 7 .pl files, what Tommy said is true, Home Designer Pro cannot open such antique files. Specifically, you would have to share your plans with a person who has Chief Architect Premier X8 (which can open and convert old .pl files to .plan files which can then be marked "Allow editing in Home Designer Projects". Like it or not, the rules are the rules with digital files and conventions. DJP Link to comment Share on other sites More sharing options...
madcowscarnival Posted August 17, 2018 Share Posted August 17, 2018 I upgraded to X10 earlier this year from X6. The X6 version ran perfectly smooth on my Windows 7 machine. I expected Chief to remove access when I upgraded, but in the conversation with Chief, they said they would let me retain access to the license in the digital locker. It doesn't really mean much as most of my files have been saved to X10 now, but I don't think you'll have any issue with using it again. Just try to find your old install disc. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted August 17, 2018 Share Posted August 17, 2018 For the plotter, you might search something like this... https://www.bestbuy.ca/en-ca/product/startech-startech-1-port-pci-parallel-adapter-card-pci1plp/10192811.aspx? Link to comment Share on other sites More sharing options...
Kbird1 Posted August 17, 2018 Share Posted August 17, 2018 On 8/17/2018 at 5:00 PM, KervinHomeDesign said: For the plotter, you might search something like this... https://www.bestbuy.ca/en-ca/product/startech-startech-1-port-pci-parallel-adapter-card-pci1plp/10192811.aspx? Expand He says he's using a Laptop Rod , so he'd need a USB to Parallel Port Cable type Adaptor instead , as above in post #4. I would suggest some research on Google with the Plotter Model No# though and make sure to find a Compatible one, though I have had good luck with Startech products and Support. Link to comment Share on other sites More sharing options...
AvoyeDesign Posted August 17, 2018 Share Posted August 17, 2018 On 8/17/2018 at 5:42 PM, Kbird1 said: He says he's using a Laptop Rod , so he'd need a USB to Parallel Port Cable type Adaptor instead , as above in post #4. I would suggest some research on Google with the Plotter Model No# though and make sure to find a Compatible one, though I have had good luck with Startech products and Support. Expand Key words in my post are "you might search something like this." IOW, google is your friend. Also, you can get pcie ribbon cables for an external hookup. Link to comment Share on other sites More sharing options...
