SawyerCD Posted August 10, 2018 Share Posted August 10, 2018 Hello to all of you Chief Architects users out there. As a new user coming from several different programs learning a new system is sometimes about as frustrating as emptying the ocean with an eyedropper. My question is this. I resonantly built all of the wall framing for one of my projects. Now when I go to my floor plan view I see every 2x4 in plan view. I don't want this as it shows up when I export it to layout and it's not very pretty for customers to look at. I've tried turning off different framing layers but with no success. How can I make the picture with the framing in the floor plan look like the picture with no framing? Thank you in advance. Link to comment Share on other sites More sharing options...
dshall Posted August 10, 2018 Share Posted August 10, 2018 turn off the FRAMING,WALL layer 1 Link to comment Share on other sites More sharing options...
SNestor Posted August 10, 2018 Share Posted August 10, 2018 Also...if you are using “plan views”...after you turn the layer off you should “save” the view. You can create a new view that just shows “wall framing”. Just copy any plan view, then turn on/off the layers you do or don’t want to see...then save that view with a unique name...such as “Wall Framing Plan” Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 10, 2018 Share Posted August 10, 2018 2 hours ago, SawyerCD said: As a new user coming from several different programs learning a new system is sometimes about as frustrating as emptying the ocean with an eyedropper. Good one! I feel your pain. I have used this software for many years and some days I am right where you are now. Link to comment Share on other sites More sharing options...
SawyerCD Posted August 14, 2018 Author Share Posted August 14, 2018 Thanks for the help guys! I've finally got this problem resolved. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 14, 2018 Share Posted August 14, 2018 One good tip I learned using plan views is to open your project browser--open plan views then select one or many then right click and open " open object" and right on top is floors, then change it to use any floor. this will not change your layout views and will keep them the way you have them set up in the layout.----now I never have that problem. Link to comment Share on other sites More sharing options...
oldmillcreek Posted August 15, 2018 Share Posted August 15, 2018 I have a question. I went through the tutorial and created a site plan. Drew the lot, but after going to the CAD tab and selecting "plan footprint" nothing was added. I tried both floor 0 and floor 1 but again nothing showed up. On the default set I see my house. What do I have wrong? Link to comment Share on other sites More sharing options...
glennw Posted August 16, 2018 Share Posted August 16, 2018 Creating a Plan Footprint does so in a Cad detail window - not in your plan view. When you created the Plan Footprint, a Cad Detail window should have opened with your Plan Footprint displayed. To check, go to Cad...Cad Detail Management. There should be an entry called Plan Footprint 1 which you can open. Link to comment Share on other sites More sharing options...
oldmillcreek Posted August 16, 2018 Share Posted August 16, 2018 I have no entries under my Cad detail management... Link to comment Share on other sites More sharing options...
glennw Posted August 16, 2018 Share Posted August 16, 2018 Did you create at least 1 closed room and then the Plan Footprint before opening Cad Detail Management? If so, can you go through the steps you used. If you don't have a closed room, you should receive an error message. Posting the plan might help. Drawing the lot has nothing to do with the process. Link to comment Share on other sites More sharing options...
oldmillcreek Posted August 17, 2018 Share Posted August 17, 2018 Okay I was able to create the plan footprint and then insert it into the plot plan. Thank you! Now I have a site plan that is crooked due to the coordinates I entered. Is this normal? See attached picture...Also adding the North pointer orientation really messed up my labeled coordinates if that makes sense. It changed them according to which way the arrow was pointed. I could not adjust arrow to get back to my angles I specified while drawing the plot. Link to comment Share on other sites More sharing options...
