Full Inch Measurements
chiefmodify
How do I manage to get the measurements onto full inches?  My framers want to kill me!!  LOL.
Cheif 9. and I'm trying to do plans up for framers, and I am having a devil of of time not getting into tiny franctions.   Can I adjust settings so this is rectified.  If so what settings.
Also best practices?
Thanks!
I have yet to find a tape measure that was graduated only in 1-inch increments. It's no more difficult to measure to the nearest 1/16" as to the nearest 1" - in the end the margin of error will be fairly consistent (about the width of a pencil lead). I understand that fractions make the math more difficult, but if the plan is adequately dimensioned there shouldn't be much math (and calculators are cheap). My advice: be logical in your layout but design as necessary, and let the fractions fall where they may.
If you are careful, you can limit dimensions to 1/4" or 1/8".
Framers should be able to hit those pretty closely but it will never be 100%.
Note that Denver is 1 mile above Sea Level but from Denver to New Orleans is well over 1000 miles.  That's only about 1/8" per foot which is the minimum code required slope for a garage floor.  Generally a slab with 1/8" variance in 10' is considered level.;)
Draw your plans by typing in exact measurements when placing objects.  Like a building's framing should be some feet' - 11" wide (like 31'-11").  Making the framing end at 11 inches allows for the sheathing to take the structure to an even foot measurement.  (like 32'-0").
Also, framers *****, moan, complain.  It's what we/they do.
Nice that you are willing to placate their concerns.
    32642
    Karysa
    Karysa
  • Similar Content
    • By ACADuser
      Creating a Header schedule I select one row & click the "Find Object in Plan" which takes me to the wall frame view instead of the plan view.
      Do I have a setting off or is this normal?
    • By KRosen
      So I'm trying to get my rafter ends to show up like so (please ignore the rafter tails for all intent and purposes). I've tried adjusting the birdsmouth settings to get the desired result but no matter what I do, I can't get the seat cut. I can only get a plumb cut or a square cut, and the plumb cut is going through the floor and walls. Can someone please help, because this is driving me crazy! (also the steeper roof pitch is 25":12")
    • By Doug_N
      This post moved to suggestions.
    • By j2narchitecture
      Hello.
      I am having issues with an exterior wall.
      There seems to be a random base plate that is generating a few feet about the first floor level.
      It appears that this plate may also be causing an issue up at the second floor where there is a hole in the exterior wall.
      I try deleting the base plate, but I am not able to select.
      How can I fix this so that the exterior wall generates properly.
      Any feedback is appreciated.
      Thank you kindly.
      See the areas circled in orange on the attached photos.
      Link to  PLAN FILE
    • By LongTermDev
      I'm having an issue where the framing members for a flat roof (1/4" slope) over a porch are not displaying correctly in the cross section. My default setting for rafter size and the specification in the roof plane dialogue for that roof plane are set to 5 1/2", but it always draws the cross section as a 2x4. If I select any of the framing members individually and open the dialogue box, it says it's 5 1/2". The trusses and framing for the rest of the house all come in correctly. Any quick thoughts come to mind?
      also, Is it better to upload a screen shot showing the problem or the whole file on here?
