HELLO, IM BULDING A NEW DESKTOP/ TOWER AND WOULD APPRECIATE ANY ADVICE ON WHICH SPECS WOULD BE BETTER FOR ME TO USE FOR CHEIF.  RAY TRACE PRODUCTIVITY IS A ABSOLUTE MUST AND I DONT WANT TO SACRIFICE GRAPHICS CARD QUALITY EITHER, I WAS DEAD SET ON THE WORKSTATION UNTIL I READ ALL OF THE COMMENTS ON HERE ABOUT THE QUADPRO NOT WORKING WELL IN CA......?  REALLY.   MOVING ON, HERE ARE MY CHOICES:
#1.  INTEL ZEON  W-2155 3.3GHz, 4.5GHz TURBO, 10C, 13.75M CACHE, HT, (140W) DDR4-2666)
       NVIDIA  QUADPRO P4000, 8GB (5820T)      32GB (2X16GB) 2666MHz DDR4 RDIMM ECC                                    WORKSTATION
        M.2 512GB PCLe NVMe CLASS 50 SSD       2.5" 1TB 7200rpm SATA HARD DRIVE
#2.  INTEL CORE I9 7900X (10-CORE, 13.75MB CACHE, UP TO 4.5GHz WITH INTEL TURBO BOOST MAX 3.0)
       NVIDEA GeFORCE GTX 1080 WITH 8GB GDDR5X         32GB QUAD CHANNEL DDR4 AT 2666MHz                    ALIENWARE
       512 GB M.2 PCLe SSD (BOOT) + 2TB 7200 RPM SATA 6Gb/S (STORAGE)
I HAVE SURFACE BOOK WITH PURFORMANCE  BASE INTEL I7 6600U 2.8 2.81 AND NVIDEA GeFORCE GTX 965M WITH 2GB DEDICATED AND I HAVE A FEW  GOOD & THEN A WHOLE BUNCH OF NOT SO GOOD DAYS WITH RUNNING (2) ASUS 27 " 1080 DISPLAYS FOR THE PAST 3-4 MONTHS IVE JUST REVERTED BACK TO ONE SCREEN BECAUSE ITS NOT WORTH THE HASSLE OF THE SCREEN FREEZING AND THE I GET "C.A HAS STOPPED WORKING.....WINDOWS IS CHECKING FOR SOLUTION..... UGH......    AND I GUESS I DIDNT EXPECT THESE ISSUES WHEN I PAID $2799.99 FOR IT 11 MONTHS AGO.  ....... AND SLIGHTLY HESITANT ABOUT THE NVIDEA GeFORCE SERIES BECAUSE OF THE LACK OF STABILITY THAT IM EXPERIENCING AND IN ADDITION, IT WOULD BE REALL REALLY NICE IF THE NVIDEA GEFORCE GTX CARDS HAD DRIVERS THAT WORKED WITH WINDOWS 10 DRIVE UPDATES BECAUSE IT SURE WOULD BE NICE TO USE MY DOOR LABEL AGAIN SOME TIME OR ATLEAST BE ABLE TO PLACE A LIBRARY OBJECT WITHOUT HAVING TO CLOSE C.A AFTER EACH OBJECT IS PLACED...... ALREADY CALLED TECH AS I HAVE SSA AND ROLLED BACK BUT THE SURFACE BOOKS JUST KEEP ROLLING BACK FORWARD....ITS BEEN GREAT... SO MOVING ON I HOPE ONE OF THESE TWO OPTIONS WILL DO GOOD AT BOTH RT AND RENDER BETTER AND HOPEFULLY BOTH MULTI THREAD WELL.  PLEASE LET ME KNOW WHICH SYSTEM YOU WOULD RECOMMEND AND IF YOU HAVE TIME LETME KNOW WHY.
THANKS
I would stay away from the Zeon's and the quadro's
Please do us a favour , don't use all caps , it is very hard to read and not good Forum ( or internet) etiquitte , thx.
I agree with Perry Chief does not benefit from typical CAD Workstation Hardware , you don't need the latest and great either , so could save a $1000 probably but get the best you can afford now , and hopefully it will stave off future upgrades longer.... go PC#2
I have rolled back to 382.05 (may) and turned Windows Driver Updates off for now using this Tutorial on TenForums
***EDIT
it seems Nvidia has removed all drivers before 385.12 from the Drivers Download page but 382.05 is still available by this direct link
http://www.nvidia.com/download/driverResults.aspx/118514/en-us
CA states you want the best gaming card and as many cores as you can afford
Quadro doesn't help with Chief, if you need it for other CAD ?
Lew
Ditto build #2.
FWIW I had a couple of Dell Precisions with Quadro cards when I first switched to Chief, switched to GTX and it's been better. As to your Surface issues- 2gb on the GPU is minimum and that most likely has Optimus which is a hassle with multiple monitors since it some will run on the Intel card instead of the GPU. My previous machine could have issues with other monitors depending on which ports I was using. I run the Saber in my Sig with the main screen, a 24", a 42" TV, and a 15" DisplayLink all at 1920 with no problem. From what I can tell it handles things comparable to many of the machines folks list here in their signatures- some better some worse, and it's a bit dated.
You may want to look over some of the recent Ray Trace threads-Graham has done a bit of research and indicates that single core performance for RT's matters even though RT will use multiple cores. Chief itself OTOH doesn't gain much from extra cores AFAIK.
There are a couple of folks on here with Xeon.s I know mrscott runs a Xeon machine for tracing but he just got an 8700k with a 1080, could likely give you a comparison. If I were getting a machine today and couldn't wait I'd talk to tech about what X10 will be happiest with, the new rendering engine they are previewing on youtube is different.
I agreed with Perry Chief does not benefit from typical CAD Workstation Hardware , you don't need the latest and great either , so could save a $1000 probably but get the best you can afford now , and hopefully it will stave off future upgrades longer....
***EDIT
I rather figured that was coming, and yes I agree.   Tech informed me that the surface book would not give me this option however, I may have misunderstood them.  I will look closer into that, thank you.
Lew
Yes, Autocad LT and Risa 3d.
2 hours ago, MarkMc said:
Ditto build #2.
I got a chance to take a quick look at the previews for x10.  PBR is intriguing, seams to be "real time" and object/code specific, depending on level of quality could be a game changer for certain projects.  I'll inquire about this tech, Thanks for the tip.
    27478
    Oilersfan20
    Oilersfan20
  • Similar Content
    • By PvdPol
      Dear all,
      I'm new to the forums and i've tried to find my way in the already existing topics, such as
      - https://www.chiefarchitect.com/products/sysreq.html
      - https://chieftalk.chiefarchitect.com/topic/21934-hardware-recommendations/?tab=comments#comment-179153
      I could not find an answer yet, hopefully some of you can help me out.
      I am currently struggling with Chief Architect Premier, ray traces are really slow at 1080P (1 pass takes like 15-30 min)
      Also working for in PBR is making my system really really slow and it is getting frustrating.
      My model is not complex and I think I need an hardware upgrade.
      Current machine (Notebook - April 2014)
      X•BOOK 15CL56 NVIDIA GTX770m 3GB, Full HD (+/- 20000 3DMARK) Intel® CoreTM i7-4710MQ (6M Cache, up to 3.50 GHz) - 47Watt (Quadcore) 16GB DDR3L (1600MHz)
        New system specifications (not bought yet)
      AMD Ryzen 7 3700X Boxed MSI X470 Gaming Plus Max Crucial Ballistix Sport LT BLS2K16G4D30AESB  (32GB Ram) Intel 660p 1TB Solidstate drive Graphic card? Nvidia? Any Advice?
      I think the 32 GB of memory is already an overkill, not sure if this is needed.
      But I'm mostly wondering regarding the choice of CPU and Graphics card
      Is this a good setup? What kind of performance improvements can I expect? What would be your advice?
      Thank you!
      Regards,
      Peter
    • By MHVisualServices
      Updated 12-8-17
      I have a client who had a set of hand drawn plans converted into AutoCAD to submit for plan check/approval.  They are missing certain components that need to be added, see "scope of work".  Have a dropbox folder for review if anyone is interested in bidding.  The completed set of CAD files will be given to an Idaho engineer for review and submission.
      Attached are samples of the files.
      W 3.pdf
      W 1.pdf
      w 4 - A.pdf
      Letter Outlining Scope of Work.docx
    • By shanecarman
      Hello,
      I have an uncle who asked me to design a dream home for his new ranch.  He has many children and wanted a large home.  I was wondering if anyone could give some general feedback on the plan and offer any suggestions?  If he likes it enough, he may give me a room in the house!  I would appreciate any feedback.  One issue I currently have is the automatic roof on the rear section of the third floor.  It is covering the windows in those rooms.  Any suggestions on that?  I would like the third floor to look smaller then the other floors from the outside but still have the rooms that are up there.  I have included a download link to the file due to it being too large to attach here.
      https://www.dropbox.com/sh/z0tyqd5rll4xfyf/AACCIhcyCHVvrAFZ-4fWIGJqa?dl=0
      Thank you for your support.
    • By fredgar52
      Hi, I'm fairly new to the Chief Architect community. Hello to everyone! I'm still learning about CA (I've been using YouTube to teach myself). I would appreciate help from all the experienced users, hopefully creating professional friendships. I'm from Miami, FL and would love to learn more about this program. It's a pleasure to be a part of this community!
      As I'm still learning the bits and pieces, I'd love to learn more on building elevation layouts. Unfortunately, I'm still struggling with converting plans to elevation layouts. Also, has anyone encountered obstacles with measurements? I'm the designer at a kitchen cabinet company. Often, the actual wall measurements taken at the home don't always work in Chief. Often by a couple of inches, sometimes by a foot or more. I'm worried I'm still messing up on the 3D renditions.
      Could someone help me out? I'd love to learn how to make the elevation layouts. And some reassurance would be awesome!
      Thanks in advance! I look forward to meeting new mentors and friends!
