Ridge_Runner Posted September 29, 2017 Share Posted September 29, 2017 I am considering going to a TV for a monitor in addition to my 24" HP monitor. My existing HP runs at 1920x1200 native resolution thru a DVI connection. I could possibly go to a 4K TV but that may be overkill for me. My eyes are tired and don't work as good as they used to; I have been looking at monitors for many years. What would you guys suggest that you know works. I am mostly concerned with clear linework and text size/clarity on the new one. I believe Joe uses a 55" to keep his plan on and others, I guess, for his various views and menus. I know some of you may use just one TV with everything on it. I don't want to open Pandora's Box here with all of the variations but I am hesitant to go to a TV without some guidance from those who use them for Chief. I believe my 1070Ti card with 4gb will handle it OK. Any problems running a 1080P TV and a 1920x1200 monitor together? I guess the text clarity is my biggest concern, now that I think about it. TIA, Mike Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 29, 2017 Share Posted September 29, 2017 I use a tv monitor ( largest) with a second just monitor. For me Dvi just gave me 720p so you must use an "HDMI" connection for full 1080p. Also some TV's tell you they are 1080p but are really 720p, Check the spec's Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 29, 2017 Author Share Posted September 29, 2017 Typo - I have a 1050Ti video card, not a 1070. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 29, 2017 Author Share Posted September 29, 2017 Hi, Perry. I seem to recall you mentioning in the past that your eyes are not as good as they used to be either. How does the text look, zoomed out on a plan, at 1080P? What size TV's are you running? Link to comment Share on other sites More sharing options...
CharlesVolz Posted September 29, 2017 Share Posted September 29, 2017 On 2/11/2017 at 4:53 AM, CharlesVolz said: Check an old post regarding SEIKI 4K TV's used for monitors. I have and 39" and a 42" that work great and are inexpensive. They make bad TV's (in 2015) because of the refresh rate which does not affect their use as monitors. I bought the 39" for under $400, then wished I would have bought an even larger one. (I came from a 27" monitor.) The 42" is better for me than the 39". I cannot go any larger because it sits on my desk and a larger monitor would make my neck hurt because of the viewing angle. I moved all of the icons to the bottom which helped a lot. Expand Link to comment Share on other sites More sharing options...
Electromen Posted September 29, 2017 Share Posted September 29, 2017 Does you video card have HDMI? One of the things you have to watch with DVI is that not all video card support HDMI and DVI at the same time. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 29, 2017 Share Posted September 29, 2017 On 9/29/2017 at 5:21 PM, Ridge_Runner said: Hi, Perry. I seem to recall you mentioning in the past that your eyes are not as good as they used to be either. How does the text look, zoomed out on a plan, at 1080P? What size TV's are you running? Expand I have a 42" tv and a 37" monitor off to the side which I use for photos and libraries. You can adjust the text in windows settings, still have to zoom sometimes, can't get away from that.I'm pretty sure every video card today has more than one HDMI port. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 29, 2017 Author Share Posted September 29, 2017 On 9/29/2017 at 6:24 PM, Electromen said: Does you video card have HDMI? Expand Yeah, it has 3-HDMI, 1-Display port, and 1-Dual-Link DVI-D port, which I am currently connected to. My 24" HP can also be run from HDMI I think; never have hooked it up that way; seems like HP recommended the DVI when I first rec'd it and hooked it up. On 9/29/2017 at 6:24 PM, CharlesVolz said: Check an old post regarding SEIKI 4K TV's used for monitors. Expand I remember this post now that you mention it. Wasn't sure how far back it was. Link to comment Share on other sites More sharing options...
lbuttery Posted September 29, 2017 Share Posted September 29, 2017 I've been using a 37" tv since 2008 I have it set about 8' away and I have it set for 720P due to my eyes I think it works fine for chief clients were able to sit back and see it without having to sit shoulder to shoulder I wasn't able to use HDMI or DVI back in 2008 someday I will replace it it has a fairly large dead area due to a ceiling light in a prior apartment it bugs me sometimes but not enough to replace it be aware of intense lighting hitting the screen - it can kill pixels Lew Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 30, 2017 Share Posted September 30, 2017 I use a 40" 4k...game changer...only thing to note is had to get used to faster mouse speed when transitioning from my laptop Link to comment Share on other sites More sharing options...
