warrenwest Posted June 23, 2017 Share Posted June 23, 2017 Hi all. How dow get my bottom 2 steps to have a different width from the rest? I need to recreate the stairs below but can't find any applicable settings to do that? Link to comment Share on other sites More sharing options...
ShaneK Posted June 23, 2017 Share Posted June 23, 2017 Link to comment Share on other sites More sharing options...
warrenwest Posted June 23, 2017 Author Share Posted June 23, 2017 Yep, thanks guys ! that will do. Half an hour of trying to figure it out by myself and 2 seconds for a workable response. Chieftalk is awesome Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 23, 2017 Share Posted June 23, 2017 You can also set the stairs as winders and use invisible walls to the sides. The stairs will expand to those invisible walls. 1 Link to comment Share on other sites More sharing options...
johnny Posted June 24, 2017 Share Posted June 24, 2017 2 hours ago, DRAWZILLA said: You can also set the stairs as winders and use invisible walls to the sides. The stairs will expand to those invisible walls. I was trying to search for this function - how do you get that to activate? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 24, 2017 Share Posted June 24, 2017 54 minutes ago, johnny said: I was trying to search for this function - how do you get that to activate? Open the Staircase DBX and on the General Tab there is a Checkbox for Winders. Link to comment Share on other sites More sharing options...
glennw Posted June 24, 2017 Share Posted June 24, 2017 5 hours ago, johnny said: I was trying to search for this function - how do you get that to activate? You need a bit more than just walls. The walls need to form a room. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 24, 2017 Share Posted June 24, 2017 11 hours ago, glennw said: You need a bit more than just walls. The walls need to form a room. I maybe missing something but I have found that true for Exterior Stairs but not always for Interior Stairs but I think that is likely due to the Exterior Walls forming the "Room" , for example Warren's simple stairs with the one side flare/angle work, at least in a simple test plan. Link to comment Share on other sites More sharing options...
glennw Posted June 25, 2017 Share Posted June 25, 2017 Mick, You are correct. In your example above, the stairs are contained in a room. Try breaking the room definition formed by the large room and see what happens to the winders Link to comment Share on other sites More sharing options...
Kbird1 Posted June 25, 2017 Share Posted June 25, 2017 18 hours ago, glennw said: Mick, You are correct. In your example above, the stairs are contained in a room. Try breaking the room definition formed by the large room and see what happens to the winders thanks for the followup Glen....I'll have to play around with it more.... M. Link to comment Share on other sites More sharing options...
