VHampton 18 Posted February 14, 2017 Hi All, The new version has a glitch when attempting to Ray Trace even something as simple as four walls and a base cabinet. Have tried all the possible fixes and it won't get past go. Anyone else? Is there a setting somewhere? Thanks in advance. Val Share this post Link to post Share on other sites
DRAWZILLA 779 Posted February 14, 2017 update your video card, never heard of an NVidia 4g. See if that works first Share this post Link to post Share on other sites
VHampton 18 Posted February 14, 2017 Thanks Perry. I went to update the driver and Windows deemed it up to date. I may be wrong. For whatever reason X8 can spew out Ray Traces like nobodies business. X9 is still a mystery. Share this post Link to post Share on other sites
DRAWZILLA 779 Posted February 14, 2017 All I know is that I haven't had a problem like that. Share this post Link to post Share on other sites
VHampton 18 Posted February 14, 2017 I'm glad that you haven't. Thanks again though. My video card is a GeForceGTX745 with 4 gigabytes of muscle. ie...4G Oh well. Back to X8. ....This latest version only seems to have stair rail options, and so far, ...that's all I can see, other than the camera settings and line work options are more intricate. ...Not so sure that the beta upgrade is worth the hassle, especially when this kind of stuff happens. Share this post Link to post Share on other sites
DRAWZILLA 779 Posted February 14, 2017 X9 actually has a lot of good stuff if you look further. your 745 is on the old side. I think the problem is something or setting on your side. Share this post Link to post Share on other sites
VHampton 18 Posted February 14, 2017 Thanks again Perry. It's only been a few weeks since the beta download. Sorry to sound like a teen age girl. Will look into the 745 and see what's up with that. Appreciate your time. Share this post Link to post Share on other sites
TheKitchenAbode 573 Posted February 14, 2017 I also have a GTX 745 4GB. No problems with X9 Beta and Raytracing. Graham Share this post Link to post Share on other sites
VHampton 18 Posted February 14, 2017 Thanks Graham. This is good to know. According to the lengthy troubleshooting checklist which I followed, apparently if all else fails, it's an anti-virus setting. This seems seems strange, because X8 works just fine. Things that make you go hmmm? Share this post Link to post Share on other sites
Dermot 573 Posted February 14, 2017 You should try it with the actual release version of X9 and if you are still having a problem, then contact technical support. Share this post Link to post Share on other sites
VHampton 18 Posted February 14, 2017 It's a faulty program install. Hopefully an easy fix. I'll stop whining in about 15 min. Share this post Link to post Share on other sites
BrianBeck 34 Posted February 15, 2017 12 minutes ago, VHampton said: Out of curiosity I into the X8 program file, and copied the RayTrace folder out from the list. Went into the X9 program files and deleted the same folder. Dragged the X8 RayTrace folder into it's place. Problem solved. We're RayTracing once again. For anyone reading this we strongly advise you do not do this. This will not actually resolve the issue although it may prevent the error. You will not get the features of the X9 ray tracer, you will be using the old X8 technology. This is however a good troubleshooting step that may help us try and track down why this issue is occurring on some machines. The actual problem is likely related to the error message posted in the prior post. We are looking into the issue. Share this post Link to post Share on other sites
VHampton 18 Posted February 15, 2017 Totally agree Brian. But I finally had to do my own troubleshooting after exhausting each and every step. For what it's worth, the RayTracing results are equal to, if not better than the X8 release. Very crisp. However unorthodox a fix this this may have been, I agree not to try this without the understanding that it could backfire. It's still much better than getting an error message though. My computer is only 12 months old and it's definitely not a hardware deficiency. Have lots of ram, and 4gigs on a video card. This alone should run circles around most laptop set ups ....thank you very much for looking into this. Like you said, don't try this at home. Share this post Link to post Share on other sites
HomesByDesign 3 Posted February 15, 2017 Val, I have the same problem and Support sent the issue to the developers. Ray trace works fine on one of my computers and doesn't on another. The one it does not work on has a NVdia GTX 285 1 GB memory - yep that's vintage but the computer ray trace does work on is more vintage. I can't say I'm glad you're having the problem but it's good to know I'm not the only one, Ron 2009 Gateway FX 6801 12 GB memory intel i7 2.67 GHz - Windows 7 64 bit NVdia GTX 285 1 GB memory (a clunker now) - dual 24" monitors 1 TB SATA2 HDD 1 Share this post Link to post Share on other sites
VHampton 18 Posted February 15, 2017 Thanks for the message Ron. It's helpful to hear that it's not just a quirk on my machine alone. The failure for the RayTrace engine to start could be just about anything, including a simple NVidia setting. ....And again, by no means did I post my bush fix as a way for others to follow. Windows 7 is like having an old car, where you can get under the hood and do a bit of tinkering if you know what you're doing. ...Anyway, problem solved, even if it's not recommended! Share this post Link to post Share on other sites
Dermot 573 Posted February 15, 2017 I was discussing this issue with the lead developer for the ray trace engine last night. It looks like the problem is that the ray trace will not run if a certain system dll is missing. Apparently, this dll is installed on all of our machines in-house but not for everyone else. We are working on a fix for this. If you need any additional help, please feel free to contact technical support. Share this post Link to post Share on other sites
Chief_QA 18 Posted February 15, 2017 The missing DLL was provided in a windows update KB2999226 which may not have been installed on your system or maybe failed to install. If you run the Visual C++ Redistributable for 2015 found on the Microsoft website it should resolve your problem. https://www.microsoft.com/en-us/download/details.aspx?id=48145 Share this post Link to post Share on other sites
HomesByDesign 3 Posted February 15, 2017 4 hours ago, Chief_QA said: The missing DLL was provided in a windows update KB2999226 which may not have been installed on your system or maybe failed to install. If you run the Visual C++ Redistributable for 2015 found on the Microsoft website it should resolve your problem. https://www.microsoft.com/en-us/download/details.aspx?id=48145 Unfortunately this did not solve my problem.... I even called Microsoft to ensure I had the download you suggested and it was clearly installed. And the reason I called MS is it took a call to MS last week to have SP1 installed properly. Plan C? Thanks in advance. Share this post Link to post Share on other sites
VHampton 18 Posted February 16, 2017 Thanks to both Ed and Brian, and Dermot. The download seems to have been the solution. That said, I undid the not recommended RayTrace implant from X8 into X9...by reinserting the proper X9 RayTrace folder. Then we downloaded the Virtual C install. It now works wonderfully. . Not having seen the full ability of the new X9 RayTrace process, until I finally had it working....I was mistaken. It streams noticeably better than all previous releases. At the end of the day, I greatly appreciate the resolve, and hope that anyone who runs into this issue will go with the Chief resolution and not my method. I am not a programmer and never plan on becoming one, even if I know my way around PCs. My time is better spent drawing houses! All the best, Val Quote The missing DLL was provided in a windows update KB2999226 which may not have been installed on your system or maybe failed to install. If you run the Visual C++ Redistributable for 2015 found on the Microsoft website it should resolve your problem. https://www.microsoft.com/en-us/download/details.aspx?id=48145 0 Quote Ed Schafer SW Testing Manager Chief Architect Inc. Share this post Link to post Share on other sites
