HomesByDesign Posted February 4, 2017 Share Posted February 4, 2017 I have x9 on two computers, ray tracing works as expected on my daytime computer but not my evening computer. The error reads: "An unexpected error occurred while ray tracing". I've covered all the Knowledge Base solutions without success, could it be my Norton antivirus blocking something? My daytime computer uses McAfee, the evening computer Norton. Ray tracing has worked in all previous version of Chief. I've also upgraded my NVDIA graphics card drivers and that didn't help. Thoughts? Link to comment Share on other sites More sharing options...
MPDesign Posted February 4, 2017 Share Posted February 4, 2017 is your evening computer a laptop? if so check it isnt set to go to sleep or standby after a specified amount of time. Link to comment Share on other sites More sharing options...
HomesByDesign Posted February 4, 2017 Author Share Posted February 4, 2017 7 minutes ago, MPDesign said: is your evening computer a laptop? if so check it isnt set to go to sleep or standby after a specified amount of time. It's a desktop Michael,,,sleep mode is inactive. The error message comes up the moment I select "run",,, as if something out there is saying "go fish"... Link to comment Share on other sites More sharing options...
MPDesign Posted February 4, 2017 Share Posted February 4, 2017 does x8 raytrace work? Link to comment Share on other sites More sharing options...
HomesByDesign Posted February 4, 2017 Author Share Posted February 4, 2017 5 minutes ago, MPDesign said: does x8 raytrace work? yes it does work in x8 and all previous versions, i'm looking at my Norton as we speak thinking it's a firewall issue,,,, Link to comment Share on other sites More sharing options...
MPDesign Posted February 4, 2017 Share Posted February 4, 2017 I see you commented that it works. try and figure out what's different about the 2. graphics cards, CPU, version of windows? don't know you haven't shared enough info. Link to comment Share on other sites More sharing options...
HomesByDesign Posted February 4, 2017 Author Share Posted February 4, 2017 5 minutes ago, MPDesign said: I see you commented that it works. try and figure out what's different about the 2. graphics cards, CPU, version of windows? don't know you haven't shared enough info. I dismissed the graphics card issue since it's worked well up till now,,,, I know the card I have here at home is an older nvdia card and I'm not opposed to an upgrade if that's the issue but since it's works on all other version of Chief had me going in a different direction Link to comment Share on other sites More sharing options...
HomesByDesign Posted February 4, 2017 Author Share Posted February 4, 2017 Well it's not Norton, I just disabled Norton, tried a ray trace and get the same. I'll have to call tech support on Monday,,,, To add to the error the details read (for what it's worth): C:\p4sync\dev\Releases\19.0.3\chief\source\raytrace.cpp(495): Error #272032345 "An unexpected error occurred while ray tracing." 2/4/2017 11:49:06 AM Build: 19.0.3.50x64 Link to comment Share on other sites More sharing options...
jcaffee Posted February 4, 2017 Share Posted February 4, 2017 Did you reboot CA and the computer? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 4, 2017 Share Posted February 4, 2017 What's the memory in your home computer, in fact you should list all your specs. Sometimes just updating the drivers isn't good enough ,but unless we know the spec's everyone is guessing. Link to comment Share on other sites More sharing options...
country Posted February 4, 2017 Share Posted February 4, 2017 Have you checked that X9 is active on your NVidia card 3D list? Link to comment Share on other sites More sharing options...
HomesByDesign Posted February 4, 2017 Author Share Posted February 4, 2017 hhmmm,,, I must add the specs to my signature as suggested, great idea,,, Old machine (it was a monster when I bought it :-) ), and actually it still performs well, 2009 Gateway FX 6801 12 GB memory intel i7 2.67 GHz - Windows 7 64 bit NVdia GTX 285 1 GB memory (a clunker now) - dual 24" monitors 1 TB SATA2 HDD Let me see what else I can find out about the graphics card.... I know when I shot a ray trace to it in x8 the fans kicked in full boar!!! :-) Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 4, 2017 Share Posted February 4, 2017 42 minutes ago, HomesByDesign said: hhmmm,,, I must add the specs to my signature as suggested, great idea,,, Old machine (it was a monster when I bought it :-) ), and actually it still performs well, 2009 Gateway FX 6801 12 GB memory intel i7 2.67 GHz - Windows 7 64 bit NVdia GTX 285 1 GB memory (a clunker now) - dual 24" monitors 1 TB SATA2 HDD Let me see what else I can find out about the graphics card.... I know when I shot a ray trace to it in x8 the fans kicked in full boar!!! :-) The video card should be a non-issue when it comes to ray tracing. Video card is used for normal render views but ray traces are ALL CPU. In fact, unless you've specifically limited certain cores to the task, you'll probably find that during ray tracing all cores will be running at a constant 100% on any computer. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 4, 2017 Share Posted February 4, 2017 Video card is weak though, Link to comment Share on other sites More sharing options...
HomesByDesign Posted February 4, 2017 Author Share Posted February 4, 2017 What a great excuse to upgrade :-). That said this is just part time gig for me (personal time) so forking out cash for something new is a challenge... Link to comment Share on other sites More sharing options...
lbuttery Posted February 4, 2017 Share Posted February 4, 2017 what is power supply on older PC probably not an issue - just asking Lew Link to comment Share on other sites More sharing options...
HomesByDesign Posted February 17, 2017 Author Share Posted February 17, 2017 This problem has been fixed. If someone else has the same experience go to the discussion titled: X9 beta version Failure to Ray Trace Link to comment Share on other sites More sharing options...
