Designers_Edge Posted June 8, 2014 Share Posted June 8, 2014 I have not had this in previous versions of Chief. I placed a 42" high half-wall using the straight half-wall tool to open the kitchen to the dining room. I had used the room divider tool to go from the half wall to the opposite wall "enclosing" the room, and maintaining it's room specification of kitchen. I have deleted the room divider/invisible wall, but that does not help. It seems as if the cabinet/program is reading the half-wall as a full height wall. I would appreciate any help. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 8, 2014 Share Posted June 8, 2014 did you delete the half wall and see what happens ? rebuild it with invisible wall from end of half wall to other wall , not all the way across the room perhaps? maybe it still "sees" the invisible wall? did you hit F12 to rebuild everything yet?.... M. Link to comment Share on other sites More sharing options...
tommy1 Posted June 8, 2014 Share Posted June 8, 2014 This is an old problem. I did have a fix for it. I'll try it soon but I think you had to place the cabinet before the wall. I know I replied the fix in the old forum if you can find it. Link to comment Share on other sites More sharing options...
Designers_Edge Posted June 9, 2014 Author Share Posted June 9, 2014 Thank you both. OK, tried F12 and that did nothing. I have also closed out and opened it again. I have two more thumbnails that are interesting., The first shows what is selected when I click on that half wall. The second one shows that when I delete that half wall, the cabinet corrects itself and now has crown on the side. Again, in older versions, I used the railing tool and never had an issue. I may do that and see what happens. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted June 9, 2014 Share Posted June 9, 2014 Forget the cabinet molding and use a molding polyline for that section. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted June 9, 2014 Share Posted June 9, 2014 You can also turn off auto fillers in the cabinet defaults 1 Link to comment Share on other sites More sharing options...
Domistyle Posted February 20, 2018 Share Posted February 20, 2018 It's now February 2018, and I'm having this problem with latest, greatest version of Chief. I've deleted the half wall, put in my wall cabinets, then added a half-wall. Deleted that and drew in a railing (I know they're the same, but, desperate times call for desperate measures!) As soon as it goes in, my crown disappears on my cabinet. Link to comment Share on other sites More sharing options...
MarkMc Posted February 20, 2018 Share Posted February 20, 2018 On 2/20/2018 at 12:34 AM, Domistyle said: It's now February 2018, and I'm having this problem with latest, greatest version of Chief. I've deleted the half wall, put in my wall cabinets, then added a half-wall. Deleted that and drew in a railing (I know they're the same, but, desperate times call for desperate measures!) As soon as it goes in, my crown disappears on my cabinet. Expand On 2/20/2018 at 12:40 AM, solver said: Did you read post #5 just above? Expand Just to add to what others have said. I use ONLY molding lines always. If you are doing much with cabinets/kitchens then you use an assortment of molding stacks. Not hundreds but more than one or two right? Evey time you make a stack using a molding line (NOT molding polyline) and create. Copy it somewhere, select one length, then "disconnect selected edge. Copy that and paste it into a warehouse plan. I keep six foot lengths of each stack in rows based on ceiling height to keep things tidy I have some dashed cad lines drawn vertically for each row set 6 ft apart. To the side of each molding line I place a description ( I lean toward naming them by client) I also take a back clip section of the molding stack, shoot a cad detail from view and copy that into the warehouse plan next to the name. Won't take long until you have all the molding stacks you are likely to use but they are still easier to adjust than stacking them on cabinets. The biggest advantages of this method are- 1 NO quirky behavior; 2 you can now adjust the side overhangs to something other than the front overhang which is what happens IRL; 3 you don't have to redraw them. Just open the warehouse plan, copy and paste. Down off the soap box now. Link to comment Share on other sites More sharing options...
