dshall Posted September 24, 2016 Share Posted September 24, 2016 Does anybody know how to model this lintel and sill when I have a casing as shown. Is the sill and lintel auto or do I need to add psolids. If I need to add psolids, it would be super if we has some control over the offset of the lintel and sill from casing. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 24, 2016 Share Posted September 24, 2016 The lintel is automatic in the window settings looks like the sill (not a real sill) is a mantle from the lib. But not automatic. EDit it can be automatic if you use a molding profile Link to comment Share on other sites More sharing options...
dshall Posted September 24, 2016 Author Share Posted September 24, 2016 Here is a sample, You can create a shelf that might be better using a custom molding profile, I just used a rafter tail for mine Thanks Perry, but you did not include the casing. Note light brown "casing/stucco" between the window and the shutter. Link to comment Share on other sites More sharing options...
MarkMc Posted September 24, 2016 Share Posted September 24, 2016 Gave it a shot as millwork treatment. Still needs some work but I had something like it (just learned this month Hope it helps. Symbols in plan Link to comment Share on other sites More sharing options...
jcaffee Posted September 24, 2016 Share Posted September 24, 2016 In the plan look at the "Treatments" section. (Looks like Mark pushed send before me.) jon dsh_window.plan Link to comment Share on other sites More sharing options...
dshall Posted September 24, 2016 Author Share Posted September 24, 2016 Thanks Jon and Mark...... you used the millwork above and below casing....... I did not realize that option was there...... thanks so much! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 24, 2016 Share Posted September 24, 2016 Thanks Perry, but you did not include the casing. Note light brown "casing/stucco" between the window and the shutter. Just turn the exterior casing on. Link to comment Share on other sites More sharing options...
blayman Posted September 25, 2016 Share Posted September 25, 2016 Hi Guys, I don't want to hijack this topic, but I do have a small problem. When I try to view Perry's plan my chief X8 says it was completed in a newer version and would I like to update. So say yes and the Chief says I have the latest version. But I have no problem opening Mark and Jon's plans. My version is 18.3.1.2x64 dated June 23, 2016. Question is this the latest version or is there a newer one that I for some reason can not download? Thanks for any info and sorry for hijacking the topic. Bill Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 25, 2016 Share Posted September 25, 2016 Bill, you have the latest version, my mistake.Sorry about that Link to comment Share on other sites More sharing options...
Gawdzira Posted September 25, 2016 Share Posted September 25, 2016 @Perry, grrrrrrr, jealousy Link to comment Share on other sites More sharing options...
blayman Posted September 25, 2016 Share Posted September 25, 2016 Thanks Perry. I was afraid I was having problems. Bill Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 26, 2016 Share Posted September 26, 2016 When using the lintel and sill options in the window dbx, how do you offset either or both of those items? If there is a setting I can't seem to find it. I ran into this on a current project similar to Scott's and an OP from a recent thread who also wanted a custom lintel and sill. It would be nice to have more control over those items when they are custom. Mike Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 26, 2016 Share Posted September 26, 2016 The lintel is automatic in the window settings looks like the sill (not a real sill) is a mantle from the lib. But not automatic. EDit it can be automatic if you use a molding profile Perry, if Scott uses a molding profile like you suggest, will it apply returns on the ends like his needs (or if a crown-type molding is used)? Or are you saying he needs to use a molding line and apply the molding profile to it? Mike Link to comment Share on other sites More sharing options...
MarkMc Posted September 26, 2016 Share Posted September 26, 2016 I used "treatments " they are custom millwork symbols. Offset is controlled by the symbol origin which takes some trial and error (at least for me). Link to comment Share on other sites More sharing options...
DRAWZILLA Posted September 26, 2016 Share Posted September 26, 2016 Perry, if Scott uses a molding profile like you suggest, will it apply returns on the ends like his needs (or if a crown-type molding is used)? Or are you saying he needs to use a molding line and apply the molding profile to it? Mike What I'm trying to say is, he can use a molding profile in the window DBX for the fake planter box, then it's automatic. Link to comment Share on other sites More sharing options...
