Attic Floor method ?
Joe_Carrick
How would you create an Attic Floor?
Assume a second floor that is basically like an attic (roof comes down to the floor) and you have dormers (both shed and gable) with the exterior walls aligned with the walls below.  The roof is a 12:12 pitch.
I see 2 ways of doing this:
1.  Make the second floor just 1-1/2" tall.
2.  Make the second floor a normal height and move the roof down to the floor elevation.
Which method would you use and what are the pros/cons?
I make the second floor normal height and move down the roof planes. The pro being spaces in the dormers have the proper ceiling height or collar tie height.
The "story and a half" Cape is a common type in the Northeast. The roof sits on second floor knee walls that may be 2, 3, 4-ish feet tall.
I cannot really compare the two as I have never tried doing it with a 1 1/2" second floor. A con might be if you intend to show space under the roof you'll need to create a third floor that is open to below. Might get fussy with room definitions?
My method also. I also agree with Kevin about the manual dormers. I seem to never get the auto dormers to work right - at least how I want them work. I do many of my house plans using this method where the owner doesn't want a full 2-story.
Mike
I start with a 1.5 inch floor, build the roof, then raise the ceiling height as needed for the dormers. I always build dormers manually.
With our insulation standards we are now sitting the rafters on top of a 2x6 plate which sits on top of the floor. I almost always have an attic level floor.
