Greg_NY61 Posted April 13, 2016 Share Posted April 13, 2016 I'm having this problem with a PDF file. When PDF plan is scanned into CA and you zoom in on the are you get grid background covering some of the plan. Did anyone experienced this? Link to comment Share on other sites More sharing options...
CJSpud Posted April 13, 2016 Share Posted April 13, 2016 If that's a PDF from LO, looks like there might be some sort of view to LO that might be showing the grid. Go to your LO and see if you can select a boundary box in that area. If you have one, and don't need it, just try to delete it and see if that fixes it. Might be something totally different ..... guessing without the file. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted April 13, 2016 Author Share Posted April 13, 2016 Thanks! I will check when I get home and let you know if that was it. Link to comment Share on other sites More sharing options...
JJohnson Posted April 13, 2016 Share Posted April 13, 2016 I was having exactly the same thing happen recently with a survey plan imported into layout. I found an pdf to jpg converter on line, changed the file,to jpg, and no more problem. Better resolution too. Link to comment Share on other sites More sharing options...
Gawdzira Posted April 13, 2016 Share Posted April 13, 2016 I also convert any image imported into CA to jpg. The pdf imports bump up the file size too much. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 13, 2016 Share Posted April 13, 2016 Move or delete it. I have had that happen before. If you have it to" save in plan" you won't get this, but if you don't, and move or delete the original than the layout box will still be there--blank Link to comment Share on other sites More sharing options...
Greg_NY61 Posted April 14, 2016 Author Share Posted April 14, 2016 Thanks everyone! It seems it's only doing that with the grid on. When I turn the grid off everything works good. I also think its a good idea to convert PDF to JPG, I just looked at the file and I only have 2 floors and the roof with some interior walls and its 4.40 MB. I will try to convert to picture. Thanks again! Link to comment Share on other sites More sharing options...
