dssharp 15 Posted April 8, 2016 Can someone tell me why when i create something out of a p solid, it's all over the place? Seems like i have to go find it. I create on level 2 and its on level 1. I create in elevation and its in the wrong place. Generally i have to create it in a new plan and copy past back to the plan im working on. What am i missing? Share this post Link to post Share on other sites
Gawdzira 214 Posted April 8, 2016 When drawing P Solids in elevation it will be on the floor where you drew it. That means that the camera view (elevation view) will be set to a floor level at the time of drawing. I often will be on the 1st floor plan and then switch to an elevation assuming that I am still on the 1st floor but the floor level reads 2 on the elevation. Share this post Link to post Share on other sites
HumbleChief 481 Posted April 8, 2016 Can someone tell me why when i create something out of a p solid, it's all over the place? Seems like i have to go find it. I create on level 2 and its on level 1. I create in elevation and its in the wrong place. Generally i have to create it in a new plan and copy past back to the plan im working on. What am i missing? Alan's advice is good but i'm still trying to figure that out after 15 years of using Chief. I can find them more easily now that I have learned where to look but it still frustrates me. If you create a p solid in elevation it will usually be created up against the nearest vertical surface, or at the camera itself if Chief can't figure out where it should go. Then it needs to be located in plan view to sit in its proper location. I've had p solids created that were simply impossible to find with my meager brain and skill set so I draw them over - a lot. Really think this needs some work for future releases. Share this post Link to post Share on other sites
dssharp 15 Posted April 8, 2016 Alan, so when using the p solid, why is it not in place in elevation and i can move it in plan view to where i need it. is there a reference of origin ? In other words when a p solid is used does chief have an origin where its placed? I would guess that from say an elevation view ,when u draw a p solid it can be anywhere related to the camera. meaning near or far. I was wondering if there was way to reference the origin in elevation view. X and y ? Share this post Link to post Share on other sites
HumbleChief 481 Posted April 8, 2016 Alan, so when using the p solid, why is it not in place in elevation and i can move it in plan view to where i need it. is there a reference of origin ? In other words when a p solid is used does chief have an origin where its placed? I would guess that from say an elevation view ,when u draw a p solid it can be anywhere related to the camera. meaning near or far. I was wondering if there was way to reference the origin in elevation view. X and y ? If there is no vertical surface like a wall Chief will create the p solid at the plane of the Camera itself - look there first. Share this post Link to post Share on other sites
dssharp 15 Posted April 8, 2016 Micheal showed that great vid on creating p solids with cad detail from view which works hands down. Just trying to figure out a faster more productive way. Share this post Link to post Share on other sites
dssharp 15 Posted April 8, 2016 Larry, yes that works. But when walls and such are in background p solids are floating around anywhere. I'm zooming out all the time to find them. Then if there are a lot of pieces they are all over the place also. Share this post Link to post Share on other sites
dssharp 15 Posted April 8, 2016 So i guess the question is , is there a way to set the origin? Share this post Link to post Share on other sites
johnny 458 Posted April 8, 2016 So i guess the question is , is there a way to set the origin? Not that I know - and if you draw in a certain view it means you won't be able to edit fully or even snap in other views. So then to get around that if you go make psolid sections in different views and put them together and block, moving that block often results in glitch-outs. I have been able to use "place point" to get some better control - but as Larry said needs work badly. Share this post Link to post Share on other sites
dssharp 15 Posted April 8, 2016 Mabey a model in place in the dbx would work. I'm putting it on the wish list. Share this post Link to post Share on other sites
Gawdzira 214 Posted April 8, 2016 My misinformation was not correct (double, triple negative that!). Actually, for misinformation it was correct. Either way, I have been experimenting and the floor level shown on the tool bar seems to not impact the floor level of the p solid. The location in relation to the floor level that you draw it does. At least in my test plan. Share this post Link to post Share on other sites
Joe_Carrick 2313 Posted April 8, 2016 Look in the dbx for the PSolid. X8 provides values/options for "Relative Position". Share this post Link to post Share on other sites
Alaskan_Son 2458 Posted April 8, 2016 Here guys, from the Help files... "The polyline solid is placed in front of any objects visible in the view. If no objects are behind it, the polyline solid is placed one foot in front of the camera." Share this post Link to post Share on other sites
dssharp 15 Posted April 8, 2016 Thanks guys ill play with that. I m on the crash burn pc , Re imaging windows.... this blows. lost rights to opening zip files ect. Hope im not hacked. Share this post Link to post Share on other sites
