manchu49 Posted May 4, 2014 Share Posted May 4, 2014 does anybody know how to cut the terrain so a culvert in a ditch under a driveway looks like it is not filled with dirt? I created the ditch, then added a structural tubing under the driveway for a culvert. The problem is that the terrain still shows inside of it. Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 5, 2014 Share Posted May 5, 2014 Post a plan copy or at least a screen capture or sketch. Lots of us "know how" but it is not clear what you want to do that you presently can not do with illustration. DJP Link to comment Share on other sites More sharing options...
GerryT Posted May 5, 2014 Share Posted May 5, 2014 AS david mentioned, you should post whatever you have attempted of your plan as I doubt that you have correctly discribed your effort(s). The Terrain can be modified in various ways to create a ditch in Chief. The easest is to use a stream. However, a driveway or road will follow that depression (ditch) so you're trying to use conflicting features as you described. One approach would be to create the depression (ditch), then fill in the driveway section with a solid. The culvert through it could be simulated by subtracting out a horizontal cylinder section. if you used a stream it's height could be adjusted to the bottom of the culvert. The reamining problem would be the crossing driveway. Unfortunitely the driveway will follow the terrain even through the depression is filled with a solid (culvert and fill)., so you could use a polyline. But then if the terrain was sloped on either side, the polyline would not follow the terrain slope. So the conflict. IOW , I believe this could only be done on a flat plan which is probably not your situation. A workarould would then be to use a polyline aross the culvert and then driveways on either side connected and blended together to look like one road. No good solution here. Link to comment Share on other sites More sharing options...
manchu49 Posted May 26, 2014 Author Share Posted May 26, 2014 Thanks for the help as I understand what you are saying GerryT,but to clarify I created depressions on both sides of the driveway, and put a pipe in under the driveway as shown in the picture. I don't know if there is a way of cutting the terrain where I need to Link to comment Share on other sites More sharing options...
Solution Kenoeightspot Posted May 26, 2014 Solution Share Posted May 26, 2014 Place a plug the same color just inside the pipe. Or Polyline solids. Third image is overview of hollow pipe 2 Link to comment Share on other sites More sharing options...
dshall Posted May 26, 2014 Share Posted May 26, 2014 Place a plug the same color just inside the pipe. Or Polyline solids. Nice job Bill, but not clear on what you did, would you mind elaborating. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted May 26, 2014 Share Posted May 26, 2014 In the first Image I made the terrain very steep at the edge of the driveway falling into the culvert. Add a polyline solid circle(plug) and set it in the pipe about 18" to hide the terrain. In the second image I made the terrain vertical at the edges of the driveway. I made a terrain ditch, the driveway followed the ditch so I added a p solid driveway (bridge) over the sloped driveway then added another p solid below the driveway p solid to act as the steep terrain sides, and in elevation shaped a hole in the p solid to let the hollow pipe show thru. 1 Link to comment Share on other sites More sharing options...
Rich_Winsor Posted December 15, 2014 Share Posted December 15, 2014 For what its worth I had occasion to revisit this topic as I needed to model a culvert that was slightly more sophisticated than just a pipe in the ground. I ran into the same problem the OP had in that whenever I lowered the culvert into the terrain it filled the hole in the culvert. I experimented with Bill’s approach of putting plugs in the ends of the hole but I couldn’t make it work. However what did work for me was to place the culvert into a terrain hole of the identical size. Anyhoo… this is what I came up with. Link to comment Share on other sites More sharing options...
rlackore Posted December 15, 2014 Share Posted December 15, 2014 Rich, Would you be willing to post this part of your plan? I would really like to be able to open it and study how you did things. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted December 16, 2014 Share Posted December 16, 2014 Here you go Robert. Be advised that reverse engineering my plans can lead to severe mental anguish. Culvert-10.plan Link to comment Share on other sites More sharing options...
rlackore Posted December 16, 2014 Share Posted December 16, 2014 Here you go Robert. Be advised that reverse engineering my plans can lead to severe mental anguish. Thank you - I really appreciate it. I struggle mightily with anything related to terrain. Link to comment Share on other sites More sharing options...
