Screen Resolution Problem On 75" , 4K, Smart Tv
mikes616
The GeForce line from the 660 and up have 4k capability, including the Titan series.
Johnny makes a good point concerning image quality on a Tv versus a true monitor. Keep in mind that on a very large screen Tv that those pixels are spread out over a very large area. Sharpness is a function of pixel density, the bigger the screen the more pixels just to keep the same image quality.
Graham
Graham
I should have clarified the term "true".  Yes,  other cards can display at 4k, but the buffering required creates a delay.  I suppose for the type of work we're talking about it may be fine, but running anything past 30 FPS only 2 cards can do that - Nvidia’s Titan X and AMD’s dual-GPU Radeon R9 295x2.
Any other card that can "handled" 4k is taxing it to a point where you are talking 16-20 FPS which is noticeably slow.   So if you are rotating a high res 3D model its going to jump around a bit (but again, maybe this is fine).
http://www.pcworld.com/article/2906385/4k-monitors-everything-you-need-to-know-about-ultrahd-pc-displays.html
Hi Johnny, I'm in full agreement. Having the capacity for 4K and actually delivering acceptable performance are two distinctly different parameters. I understand that from other postings that some users who have gone the 4K route have been experiencing performance related issues. That's a lot of pixels to crunch and without some top notch hardware one is likely to experience some lag, especially if they are multi-tasking at the same time. Just imagine running a video, having a Raytrace running in the background while working in Chiefs camera view.
Graham
New Mac Pros will support 4K.
  • Dual display and video mirroring: Simultaneously supports full native resolution on the built-in display and up to 3840 by 2160 pixels on up to two external displays, both at millions of colors.
  • Thunderbolt digital video output
  • Native Mini DisplayPort output
  • DVI, VGA, dual-link DVI, and HDMI output supported using Mini DisplayPort adapters (sold separately)
  • Support for up to 5120-by-2880 resolution at 60Hz on a single external display (model with AMD Radeon R9 M370X only)"
Same for me. Just use my TV for client presentations. TVs are designed to be viewed from a certain minimum distance, not conducive in a work desk/station environment. If you are too close you will likely experience eye strain and as mentioned above you tend to have to keep moving your head a lot to focus on a particular region of the screen. With a regular sized true monitor everything is within your field of vision. Bigger is not always better!!!
Graham
