Multiple appliances in a cabinet
RGWhite
Well I found the answer.  It appears that if you try to insert an appliance into a cabinet you MUST select the library item from the DBX for cabinet spec.  I tried to select from the library directly and it would not work.  When watching the Knowledge Base it was not clear that this is the ONLY way to do it.  I think it would be a good suggestion for CA to list common errors in the Knowledge Base along with the process.  Thanks everyone for your responce.
