Exterior walls
Jibs75
You have wall layers on the wrong side
You have walls that are not 90degrees in the corners
You have either an invisible wall, or a mis-alligned wall with a wall below that is creating an attic wall that is cutting the wall above it.
But I am just going of what is in the pic.
Just delete the short offending part then drag the other wall to correct location and square it up at same time. External wall drawn continously in 1 direction as we had to do back in the early versions seems to solve most of these user error problems.
