HDPWestCoast Posted yesterday at 12:58 AM Share Posted yesterday at 12:58 AM Recently upgraded to X17 and my only options are SAVE and MAKE A COPY and for the life of me, I have no clue where the make a copy file is going. Link to comment Share on other sites More sharing options...
mtldesigns Posted yesterday at 01:38 AM Share Posted yesterday at 01:38 AM 38 minutes ago, HDPWestCoast said: SAVE and MAKE A COPY and for the life of me I see "Save As" under the File pull down. I also have mine set up not using the project management tool too, so I don't know if that is different. Can you make a copy via explorer? Link to comment Share on other sites More sharing options...
PitMan71 Posted 23 hours ago Share Posted 23 hours ago 17 hours ago, mtldesigns said: I see "Save As" under the File pull down. I also have mine set up not using the project management tool too, so I don't know if that is different. Can you make a copy via explorer? Same here.... I bet that has something to do with project management turned on. Link to comment Share on other sites More sharing options...
DBCooper Posted 18 minutes ago Share Posted 18 minutes ago X17 is going to work differently than older versions when you have project management turned on. So you can either turn off the project management or learn how to use it. These might be a good starting point: https://www.chiefarchitect.com/support/article/KB-03217/working-with-the-project-browser-using-project-management.html https://www.chiefarchitect.com/support/article/KB-03205/copying-projects-or-files-using-project-management.html Or, if you just don't want to learn how to use it: https://www.chiefarchitect.com/support/article/KB-03210/enabling-or-disabling-project-management.html Link to comment Share on other sites More sharing options...
