winterdd Posted 3 hours ago Share Posted 3 hours ago How do you guys taper joists when the program doesn't do it? See below and thanks! Link to comment Share on other sites More sharing options...
rwdozier Posted 2 hours ago Share Posted 2 hours ago I don't know where the setting may be, but mine is automatic. Link to comment Share on other sites More sharing options...
Gawdzira Posted 2 hours ago Share Posted 2 hours ago Possible situation is that your ceiling at the open porch area is set too high. Link to comment Share on other sites More sharing options...
PitMan71 Posted 55 minutes ago Share Posted 55 minutes ago 2 hours ago, winterdd said: How do you guys taper joists when the program doesn't do it? See below and thanks! I had this come up a week or so ago. In a section view, drag the bottom of the joist more toward the roof and it should clip it. Also, there might need to be a railing wall or beam there for it to recognize that there is something to bear on. In my case, there was an exterior wall. I just drug the joist toward the roof and the system clipped it. You can always just turn off framing layer in that view AND you might be able to apply a profile to those ends if the above doesn't work. That ways my backup plan. Just remember you can only scarf cut a joist so much before its structural integrity is compromised. Link to comment Share on other sites More sharing options...
