cjanderson66 Posted Friday at 09:02 PM Share Posted Friday at 09:02 PM (edited) I am not sure what I have done to my default settings but I need your help. Some how my sill plate is not showing up when I build my framing and there is a 3/4" space below the floor framing. Secondly, it is also throwing in an 3/4" X 1-1/2" RIM JOIST at the end of the floor sheathing. I have gone through all of my preferences but just can't figure this out and I don't have the time to keep going through this for such a small job. Any help would be greatly appreciated. Thx. Edited Sunday at 08:21 PM by cjanderson66 Link to comment Share on other sites More sharing options...
Chrisb222 Posted Saturday at 01:56 PM Share Posted Saturday at 01:56 PM 16 hours ago, cjanderson66 said: Any help would be greatly appreciated. Your topic isn't getting attention because no one can troubleshoot your file from a picture of the problem. If you post the plan I'm sure it will get resolved. Link to comment Share on other sites More sharing options...
joey_martin Posted Saturday at 02:07 PM Share Posted Saturday at 02:07 PM The 3/4" gap is because you have the sub-floor layer checked as framing, uncheck that box. As for the sill plate, that setting looks off as well and is found in the foundation ddx. 1 Link to comment Share on other sites More sharing options...
cjanderson66 Posted Sunday at 08:07 PM Author Share Posted Sunday at 08:07 PM On 10/11/2025 at 8:07 AM, joey_martin said: The 3/4" gap is because you have the sub-floor layer checked as framing, uncheck that box. As for the sill plate, that setting looks off as well and is found in the foundation ddx. I knew I could count on you Joey... Any idea why my sill plate is not showing up and is only 3/4" gap? Link to comment Share on other sites More sharing options...
joey_martin Posted yesterday at 12:24 AM Share Posted yesterday at 12:24 AM 4 hours ago, cjanderson66 said: I knew I could count on you Joey... Any idea why my sill plate is not showing up and is only 3/4" gap? Not without your plan file. It could be your SILL PLATE default is overriding the setting you are showing above, or a framing setting is throwing something off. I've not seen this situation before. Link to comment Share on other sites More sharing options...
GeneDavis Posted yesterday at 03:19 AM Share Posted yesterday at 03:19 AM If you're not going to post the plan, screencap all the fdn settings and show us. 1 Link to comment Share on other sites More sharing options...
cjanderson66 Posted yesterday at 03:38 AM Author Share Posted yesterday at 03:38 AM 17 minutes ago, GeneDavis said: If you're not going to post the plan, screencap all the fdn settings and show us. Alright here is a backup plan since I don't even know where plans are stored anymore with the new X17. We used to be able to save them in our own files system but where are they? Just another question I had Castlebar_2025_10_12.plan Link to comment Share on other sites More sharing options...
Solution robdyck Posted 16 hours ago Solution Share Posted 16 hours ago Hi Chris, the problem is that the foundation wall is currently hardwired for this incorrect sill plate. I don't know why, but Chief is holding on hard to an incorrect setting. To fix this, you need to use the Import Settings tool. Select his and then navigate to and select the template plan file for X17. Once you have the file selected, choose the foundation wall and select the Replace option. Press F12 and the sill plate will build correctly. The foundation walls will also rebuild correctly, BUT Chief will not display them correctly until they are selected, and open-closed! Then, the top of foundation wall will be displayed correctly as well. Oddly enough, the sill plate will be an OSB material. 1 Link to comment Share on other sites More sharing options...
robdyck Posted 16 hours ago Share Posted 16 hours ago You will also need to replace the default Floor and Ceiling Platform setting to correct the material used for the sill plate. 1 Link to comment Share on other sites More sharing options...
