timARTdesign Posted August 5, 2025 Share Posted August 5, 2025 I have watched all the videos and wanted to see if anyone out there has a complete layer set templates that i could use? Looking for all the different layer sets to create extremely detailed plans using layer sets. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 5, 2025 Share Posted August 5, 2025 The Layer Set for Layouts is very simple. For Plans it gets complicated and is probably evolving over time. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted August 5, 2025 Share Posted August 5, 2025 1 hour ago, timARTdesign said: I have watched all the videos and wanted to see if anyone out there has a complete layer set templates that i could use? Looking for all the different layer sets to create extremely detailed plans using layer sets. You really should use Default Sets. The layer set is included, but you also have all of your annotations set up correctly (style, text style, color, layer, etc.) If you are not using Default Sets (at a minimum), you are wasting a lot of time and creating a lot of errors on plans. Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 5, 2025 Share Posted August 5, 2025 @Renerabbittsells a template plan. You could ask him if his has what you need. I will also add that the use of saved plan views which use default sets, makes things a lot more consistent Link to comment Share on other sites More sharing options...
Kbird1 Posted August 8, 2025 Share Posted August 8, 2025 On 8/6/2025 at 4:28 AM, SHCanada2 said: I will also add that the use of saved plan views which use default sets, makes things a lot more consistent I agree SVPs are very powerful, and it's fairly simple using duplicate to make one for each View needed along with a dedicated Default Set which includes dedicated Layersets etc. M. Link to comment Share on other sites More sharing options...
chiefjone9 Posted October 16, 2025 Share Posted October 16, 2025 I also looked for a complete template but most people seem to build their own based on project needs. Personally I think starting with the default sets and customizing step by step works best. Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 13 Share Posted February 13 The templates I sell are in their 10th year of development and 4th commercial year. The X17 versions alone had a dedicated four months of full time development. These are crowd funded systems, built specifically for the end user to deliver the best out of the box automation possible while limiting liability. The tools and annotations are designed to derive information directly from the model, creating a systematic and efficient workflow. Instead of relying on manual input, the system leverages pre-defined annotations and model-driven variables to produce consistent, reliable documentation. Each template includes a pre-configured project file with a wide range of scoped views already organized and sent to 12 different layout files. It includes six distinct title block styles and multiple viewer scopes, such as a design review set versus a construction build set, allowing you to quickly generate the appropriate deliverable for each phase of a project as soon as you start drawing your walls. Comes with over 1200 library items including a bunch of single click tools built into custom toolbars to make complicated tasks easy and accessible. That's my pitch, thanks for the mention Jason Link to comment Share on other sites More sharing options...
