Roof Rafter Spacing
builtright3
Ok, so I changed the roof rafter default settings from 24" to 16" and when I rebuild the framing my rafters are still at 24". Never remember having this problem before? Should be simple!
I thing the Chief "gremlins" are attacking again! Or I'm just tired because I have been up most of the night working on this drawing.
I know I have been really needy lately but Help!
Bill and Mick are correct in that default changes do not immediately take effect, you must either have "Auto Framing" checked "on" OR manually order the framing rebuilt after making the default changes, it is not automatic unless you order it so, manually.
I did all that and I deleted all the framing and started over and set the spacing and rebuild in manually and automatic. I tried it and the spacing does not change. I went out of the plan and back it, I reset everything in every way I could think of. I have to be missing something though unless there is a glitch in the system.
