JBi-PDX Posted July 4, 2025 Share Posted July 4, 2025 When I place a doorway in a wall, the drywall layer doesn't show as wrapping the opening in plan view. Why is this? I've checked all my layers so that only the framing layer is set at framing. The two drywall layers are set as interior and exterior layers. It appears correctly in 3D, but not plan view. It's kind of annoying that it doesn't show up correctly. drywall.pdf Link to comment Share on other sites More sharing options...
PitMan71 Posted July 4, 2025 Share Posted July 4, 2025 I have noticed that too. I haven't worried too much about it. Link to comment Share on other sites More sharing options...
Rookie65 Posted July 4, 2025 Share Posted July 4, 2025 Did you remember to delete the jamb and casing from the doorway? Link to comment Share on other sites More sharing options...
JBi-PDX Posted July 4, 2025 Author Share Posted July 4, 2025 Rookie65 - good question. Yes, I did remove the jamb and casing. I actually have that set in my defaults for doorways. Link to comment Share on other sites More sharing options...
DBCooper Posted July 4, 2025 Share Posted July 4, 2025 You might get close to what you want by turning on the jamb, making it 1/2" thick, and setting the material to drywall. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted July 4, 2025 Share Posted July 4, 2025 7 hours ago, JBi-PDX said: When I place a doorway in a wall, the drywall layer doesn't show as wrapping the opening in plan view. Why is this? I've checked all my layers so that only the framing layer is set at framing. The two drywall layers are set as interior and exterior layers. It appears correctly in 3D, but not plan view. It's kind of annoying that it doesn't show up correctly. drywall.pdf 158.61 kB · 17 downloads I think you should report that as a bug. 1 Link to comment Share on other sites More sharing options...
mthd97 Posted July 5, 2025 Share Posted July 5, 2025 @Renerabbitthad a free wall cut away symbol/tool, that might work for now if it looks right in plan view as well ? Link to comment Share on other sites More sharing options...
mtldesigns Posted July 5, 2025 Share Posted July 5, 2025 15 hours ago, JBi-PDX said: the drywall layer doesn't show as wrapping the opening in plan view. Why is this? It's been doing this as long as I can remember.. I just learned not to worry about it, like Shane. BUT if I needed to show it, I'd do exactly what DB suggested. Link to comment Share on other sites More sharing options...
PitMan71 Posted July 5, 2025 Share Posted July 5, 2025 20 hours ago, DBCooper said: You might get close to what you want by turning on the jamb, making it 1/2" thick, and setting the material to drywall. Only issue with this that I can see is that in the 3D view the base molding doesn't wrap around the inside edge of the doorway. 17 hours ago, Doug_N said: I think you should report that as a bug. This I agree with. Seems like without any trim this would be obvious. 1 Link to comment Share on other sites More sharing options...
Doug_N Posted July 8, 2025 Share Posted July 8, 2025 Strangely enough, although it looks wrong in plan it is fine in 3D including the molding continuing around the jamb or through when flush with the wall. I then wondered, what if you didn't want the moulding on the door opening, but I haven't experimented with that yet. Link to comment Share on other sites More sharing options...
