How come drywall doesn't show up when there is a doorway? See attached pic.
JBi-PDX
When I place a doorway in a wall, the drywall layer doesn't show as wrapping the opening in plan view. Why is this? I've checked all my layers so that only the framing layer is set at framing. The two drywall layers are set as interior and exterior layers. It appears correctly in 3D, but not plan view. It's kind of annoying that it doesn't show up correctly.
drywall.pdf
I think you should report that as a bug.
20 hours ago, DBCooper said:
You might get close to what you want by turning on the jamb, making it 1/2" thick, and setting the material to drywall.
Only issue with this that I can see is that in the 3D view the base molding doesn't wrap around the inside edge of the doorway.
This I agree with. Seems like without any trim this would be obvious.
