Steve_Nyhof Posted June 19, 2025 Share Posted June 19, 2025 I am writing this because of the growing frustration I and others are seeing in the forum about the Project Manager There is some length to this thread, but if you read it through carefully you will be on your way to using the Project Manager with less frustration. You may even find that you are more productive and enjoying the organization it offers. From an Architects Perspective There are several videos now available by Chief going over the new Project Manager. And while they cover a number of its features, they do not really give any one clear direction on using it in your daily practice. Most likely because of the large variety of it's users and their specific use cases or industries. I am going to show how I have been using it now for about 6+ weeks, and again like the title says, I am enjoying what it is offering in an easy to access and managed way of working with my files. PM = Project Management CA - Chief Architect I am coming at this as though a new user, meaning, I have no macros working in the background, or other TXT or PDF files that make up a "Project", like you would have a project folder in Explorer or Finder. There are more advanced users here that have a much greater depth of file interaction and linking that the PM I believe it causing some issues to overcome. My use of CA I believe it very simple and similar to the majority of users. First I want to point out something important. Recommend: I would strongly recommend that you continue to draw your plans in X16, and set up X17 into Project Management mode and mess around with it to learn about all the features, and begin to work out a process and system that works for you. Below I am going to show you my system and process. NOTE: When you change into PM mode, your default plan and layout templates are copied into CA system folders. Again, it is making copies of your defaults. When you switch back to Unmanaged mode, (like you work with X16), the New Plans (see tab below) still use these copied defaults. Meaning, if you are like me, I have over the years put my default templates in a folder I manage and open them now and then to update details so the next time I create a New plan or layout, it has the latest updates. MAKE SURE to reconnect your default templates in Unmanaged mode so you see the path in the field. For many years I have stored my plan and layout files in Explorer under specified folders that mean something to how I organize my folders and files. I expect you do too. When you get into the PM, the first thing you will learn is that saving a plan is only saving that plan within the Project. CA is saving your work in their system files. Meaning you cannot access and organize them easily like you have been used to for years. So the question that is arising, is... where is my plan and layout files when I switch back to Unmanaged mode? Well, they are saved in some system folder. The only way to meaningfully access them is to switch back into the PM, and they will show up. (Read Recommend: Above) Below you can see the Project and the .plan under the Project. Before changing the system from Project Management mode to Unmanaged mode, you need to Export your project(s). Export Project is similar to the old Backup Entire Plan option. However, there is a file extension that is now called, .caproj. (Johnson.caproj for Example). You need to rename this extension (after it is exported to disk) to .zip, and then unzip this file like you did with the Backup you would unzip in earlier versions. There you will find your .plan and .layout files. You can then open these files in Unmanaged mode. Located in Explorer Creating A New Project Template Now the simple stuff. My way of operating within the PM... The first thing you need to do is create a New Project Template from your default plan and layout templates. It is in the New Project Template project that I now edit and update when I want to. Meaning, I am no longer editing my default .plan and .layout templates. I am now only editing my .plan and .layout files inside the New Project Templates project. And as you can see, they are right in front of me when I want to open and edit them as I run into something. +1 (See Linking Your .Plan and .Layout Files at the bottom for why this is great) When I want to start on a New Project, I Make a Copy of the New Project Template and Rename the new project to what I want... Rename the new project, the .plan and .layout files... Importing a .plan file from X16 If I am bringing in a .plan from X16, I still make a copy of the New Project Template first. Then Import the files I want from X16 into this new project. Organize your Projects You can add + New Folder (tags) and apply them to your projects to maintain your projects in a meaningful way (like a folder tree). Now you have a similar organization to Explorer or Finder within the PM. +1 The files you see listed above are all current projects I am working on. Meaning, the only projects I have in the PM are current projects. When the projects are completed and I know they will no longer need attention, I Delete them from the PM!! Screechhhh!! Hold on now, not so fast! We do not want to ever delete a project until we know it is safely backed up in Explorer or Finder. Export is the new Save As Here is where the old Save As comes into play. Ok, there is no Save As in X17 because now our .plan and .layout files exist inside Projects that are saved within the CA system. There is a backup system in CA, and it has its place, but because I like to put my files (projects) where I know I can find them, and where I know my backup system can find and back them up to the cloud. You know, like we do now in X16 and every other software we create files with. Today I worked on three projects. After I was done working on each one, I would Export the project to my folders in Explorer where I have stored my files for decades. Saved in Explorer like I have done in the past. Where my cloud service will back it up if it is new or updated. I use Export as a Save As to save my .caproj project files to disk. When working within the PM, Ctrl+S/Cmd+S will save the files within the project and within the CA system. But if you want to continue with the same organization you have used forever, then Exporting the project is how you get that project and it's files into Explorer or Finder. +1 This has now become habit for me, and exporting a project file that already exists will prompt me to overwrite the existing file, and so I click on OK, as I want only the one project and the latest files within that project. The same way I would Save or Save As a file and overwrite the existing file. When I am done working on a project, I will delete the project out of the PM so it remains a manageable system. I do not worry anymore about if that project file exists in my computer folder organization because I have repeatedly exported and saved these project files to disk as I work, also knowing that these files are being backed up in a place I am in control of. +1 Importing An Old Project File If a client should come back after the project file has been deleted from the PM, I just go to my computer folder system, locate the project file (.caproj) and double click on it like I would with any other file to open it's related app. CA opens to the PM and places the project in the Projects view and prompts me to select a file to open. +1 I know a number of users create "Project" folders to store all their files in. I did some of that when there were a number of revisions, or extra files to store, but I am really loving that all my files, revisions and extra files I want to save with the project are all stored with this single Project.caproj file. +1 Linking Your .Plan and .Layout Files I'm not going to get into this much here, other than to say that when you create a New Project Template, you can also setup your .layout with numerous views all linked to your .plan file. I and others have done this in earlier versions with some tricks, but in X17, it is designed with this idea in mind. +1 Depending on your process, sharing projects with a team or syncing your projects to access them from another computer, there is a lot to like about the Project Manager. And if Chief is reading, please put together a process or two that the users can duplicate (step by step) and springboard from. It is not enough to let us know all about the features. The features will present themselves if there is a process in place that users can follow and learn from. I believe this could eliminate a lot of frustration. Bottom line, I'm getting so used to the organization I now have with the Project Manager in X17, that going back to X16 just to make some changes to a completed project does not feel as productive. I was very against the PM in the beginning because I thought I was losing control of my file organization, but I truly believe CA is better now with the PM than without it, and with some additional features it can become amazing! 1 2 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 19, 2025 Author Share Posted June 19, 2025 I put a plan together for a client under my folder - code: SND. Before I was completed, I gave the client a list of builders to call and they selected a builder whose code is JCB. So all I did is rename the project name and it's files, and then changed the (folder Tag). Nothing got broken, and nothing to relink. Simple and clean! Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 19, 2025 Share Posted June 19, 2025 15 hours ago, Steve_Nyhof said: You need to rename this extension (after it is exported to disk) to .zip, and then unzip this file like you did with the Backup you would unzip in earlier versions. There you will find your .plan and .layout files. You can then open these files in Unmanaged mode. just FYI it will be better for most people using unmanaged mode to keep the project file as a project file and it will prompt them about how they would like to import the assets that are included in the archive file. Also note that some people will be using advanced tags which behave and display very differently than the folder tags you are showing. Which is fine, as you said, this is the way you are using the system Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 19, 2025 Author Share Posted June 19, 2025 50 minutes ago, Renerabbitt said: just FYI it will be better for most people using unmanaged mode to keep the project file as a project file and it will prompt them about how they would like to import the assets that are included in the archive file. This is good to know. I did not test it Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 19, 2025 Share Posted June 19, 2025 50 minutes ago, Steve_Nyhof said: This is good to know. I did not test it and this is advanced tags: Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 19, 2025 Author Share Posted June 19, 2025 2 minutes ago, Renerabbitt said: and this is advanced tags: Ah! so they left the original tags as an option. Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 19, 2025 Share Posted June 19, 2025 1 minute ago, Steve_Nyhof said: Ah! so they left the original tags as an option. Yeah I just switched to them. Gonna give them the ole college try 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 26, 2025 Author Share Posted June 26, 2025 This is a great video by Rene. The operation is very similar to the way I use it... 1 Link to comment Share on other sites More sharing options...
Paul454 Posted June 26, 2025 Share Posted June 26, 2025 Hi Steve, I want to thank you for the post you wrote on June 18th. Your explanations along with the screen shots of how you setup new projects and how you use the new Project Manager in X17 was very clear and concise! I like the way you setup your plan and layout template files. That's kind of like the way I would setup new projects using Windows Explorer in the past. You really put a lot of time and effort into this post! Thank you, again, Steve! 1 1 Link to comment Share on other sites More sharing options...
sweethomedesign Posted June 27, 2025 Share Posted June 27, 2025 Thank you Steve 1 Link to comment Share on other sites More sharing options...
jvirostko Posted August 6, 2025 Share Posted August 6, 2025 Hey Guys, How are you handling Linked images with the new project management system? Typically when having renderings or other such images on layouts they were previously linked to the folder location. Now they are stored independently on chief and I'm not sure if there is any method left to link the images. Hence when a render needs updated, I've got to manually import it again and resize and format it each time. Have you guys run into this or have any workarounds? Thanks! Link to comment Share on other sites More sharing options...
SHCanada2 Posted August 6, 2025 Share Posted August 6, 2025 i've always used layout boxes with update on demand for renders to avoid the whole create an image from a render over and over and over again The painful part is printing, because CA then renders it again for printing Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 7, 2025 Share Posted August 7, 2025 Project management needs to have a way to link to an outside file like a PDF or spreadsheet that will maintain that link so that when you edit those documents or others in the native program that they were created, the project in Chief will update to reflect those changes without the need to re-import those files. Until that time, project management is only useful for simple projects that don’t require outside documents created in other programs. it’s half baked at this point. It’s a power user feature that isn’t for power users. it was introduced in the pro version but only useful for those at the beginner level. perplexing. Link to comment Share on other sites More sharing options...
ClintonM Posted August 7, 2025 Share Posted August 7, 2025 4 hours ago, Michael_Gia said: Project management needs to have a way to link to an outside file like a PDF or spreadsheet that will maintain that link so that when you edit those documents or others in the native program that they were created, the project in Chief will update to reflect those changes without the need to re-import those files. Can I ask for some clarification here? Do you want: 1. The ability to import an outside file into a project so that it is stored alongside plans and layouts in a project, and then be able to edit it with your program of choice such that updates are reflected in Chief Or 2. The ability to import an outside file into a project, then import it into a plan or layout, so that it is useable in your drawings, and then be able to edit it with your program of choice such that updates are reflected in your plan or layout You can already do a lot of this in X17, but there may be some behavior that is still lacking. You can currently: 1. Right click on a Project and use 'Import File(s)' to bring a file into the selected Project 2. From the Project Browser, double-click or right click > 'Open With...' on the imported file to open it in your program of choice 3. Upon saving in the external program, the file in Chief will reflect the changes made Or 1. In your open plan or layout, import a file as you would in X16 2. Note, instead of appearing in the Project alongside plans and layouts, it will be imported to 'Asset Management' (See Tools > Assert Management) 3. To edit the file, use Tools > Asset Management 4. Find the file via the search bar or the ownership dropdown 5. Once the file is found, use the 'Open' or 'Open With...' buttons to edit the Asset 6. Upon saving in the external program, the file in Chief will reflect the changes made What X17 can't currently do is allow you to easily link an outside file stored directly in a Project to a plan or layout in that Project. You first need to move the file to Asset Management. If you'd like to add this behavior, please send us a feature request or suggestion If the program isn't working like described int he steps above, please contact Tech Support or let me know here! Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 7, 2025 Share Posted August 7, 2025 7 minutes ago, ClintonM said: The ability to import an outside file into a project I always have several excel spreadsheets and pdf's included in my layout files. With the current way of working prior to Project Manager, when I make a change in Excel and re-save the file, all I have to do is open the DBX for that imported spreadsheet or pdf,(so it updates) in the layout page and the recent changes made in excel will be up to date without having to re-import the file. From what I've understood in the new Project Manager. I would have to delete the old excel or pdf file and re-import the changed version. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 7, 2025 Share Posted August 7, 2025 24 minutes ago, ClintonM said: Or 1. In your open plan or layout, import a file as you would in X16 2. Note, instead of appearing in the Project alongside plans and layouts, it will be imported to 'Asset Management' (See Tools > Assert Management) 3. To edit the file, use Tools > Asset Management 4. Find the file via the search bar or the ownership dropdown 5. Once the file is found, use the 'Open' or 'Open With...' buttons to edit the Asset 6. Upon saving in the external program, the file in Chief will reflect the changes made Hi Clinton, Is this only if I use the Project Manager? I m not and I don't see Tools > Asset Management 1 Link to comment Share on other sites More sharing options...
ClintonM Posted August 7, 2025 Share Posted August 7, 2025 18 minutes ago, Joe_Carrick said: Hi Clinton, Is this only if I use the Project Manager? I m not and I don't see Tools > Asset Management Yes, Tools > Asset Management is only available if Chief Architect Project Management is enabled in Preferences. Link to comment Share on other sites More sharing options...
ClintonM Posted August 7, 2025 Share Posted August 7, 2025 32 minutes ago, Michael_Gia said: From what I've understood in the new Project Manager. I would have to delete the old excel or pdf file and re-import the changed version. Thanks for the clarification! If I understand correctly, you can use method two above to update your excel spreadsheets within Chief and without needing to reimport the files. The one current limitation is that your spreadsheets will be stored in Asset Management, not directly in your Project, so navigating to the spreadsheet in order to update it may be a bit tedious. Give this a try and let me know what you think! 1. In your open plan or layout, import a file as you would in X16 2. Note, instead of appearing in the Project alongside plans and layouts, it will be imported to 'Asset Management' (See Tools > Assert Management) 3. To edit the file, use Tools > Asset Management 4. Find the file via the search bar or the ownership dropdown 5. Once the file is found, use the 'Open' or 'Open With...' buttons to edit the Asset 6. Upon saving in the external program, the file in Chief will reflect the changes made Link to comment Share on other sites More sharing options...
Michael_Gia Posted August 7, 2025 Share Posted August 7, 2025 2 minutes ago, ClintonM said: Upon saving in the external program, the file in Chief will reflect the changes made Well this is exactly what I was looking for. It has not been clear in the videos or information up to now so I was apprehensive to try Project Manager. I will give it a go. Thanks, for the explanation! (if it doesn't work I'll be back with my usual petty cynicism. lol ) 3 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted October 16, 2025 Author Share Posted October 16, 2025 I've been busy, so not hear much. But I wanted to give an update on this thread now that a I'm a number of months in and using the Project Browser. Here is what my folders look like that help keep me organized. I am typically juggling 20 to 30 plans at a time so that is what I have in the Project Browser. I have not changed a thing from my initial content on this post. That tells me that these folders (for me) made this all work to help keep me organized. A BIG PLUS!! The LGR folder is a builder who builds condominiums. So the sub-folders are the names of the units. Under SND (the folder for my clients - not builders) has some sub-folders where I may move a project to get it out of my main working view of active projects under SND. So just pointing out how I am using this and that it is working as expected. Now the only reason I open my main Chief Plans folder on disk (explorer) is to export a project to, or open an old project that I need to bring back into the Project Browser. Otherwise, all my operations are right here inside Chief. I have really been enjoying the improvements in X17. Great Job Team! Cough, cough... update just two things on the stairs to make a bunch old timers happy 1 Link to comment Share on other sites More sharing options...
