Larry_Sweeney Posted March 21, 2025 Share Posted March 21, 2025 I designed a one-story home with a walk-0ut basement. The walls in the basement that are in the walk-out area are pony walls with the upper section being 2X6 construction to the concrete floor and the lower (frost wall) being ICF walls. I lowered the ICF lower section of the pony walls to be 40" below the concrete floor. Up to this point everything is fine doing it this way. my problem occurs because on my foundation layout page, I like showing different render views of the foundation only, but how can I not show the upper 2x6 part of the pony walls? If I only want to show the foundation walls (masonry/ICF) along with the footers, do I have to approach my thinking differently by creating another level below my walkout level. That level would then have the ICF "frost wall" and I would change the pony wall to just a "normal 2X6 exterior wall". Is there a better way to approach my problem? As always, your time and advice are much appreciated. "IF" I have to change the lower level, which at present is the basement to something else and make the level below it the "basement", how does one go about that? It seems like a lot of cups of coffee. Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted March 21, 2025 Solution Share Posted March 21, 2025 I believe it was right here in X16 that we were first given display Layer control for the structural Layers of walls. You'll have to make use of those: 3 Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted March 22, 2025 Author Share Posted March 22, 2025 Michael......................Thank you for the "heads up". Here it is almost time for X17 and I completely missed this in X16. I'll have to do some reading with my "ONE" cup of coffee. Have a great day Link to comment Share on other sites More sharing options...
mtldesigns Posted March 22, 2025 Share Posted March 22, 2025 5 minutes ago, Larry_Sweeney said: Thank you for the "heads up". Here it is almost time for X17 and I completely missed this in X16 @Alaskan_Son WOW.. So did I Larry. I'll have to read up this myself. Link to comment Share on other sites More sharing options...
DefinedDesign Posted April 6 Share Posted April 6 On 3/21/2025 at 7:16 PM, Alaskan_Son said: Hi Michael, I have this exact walkout basement, what is your secret for getting the framed wall to sit on top of the slab? Right now mine is doing this: Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 6 Share Posted April 6 46 minutes ago, DefinedDesign said: Hi Michael, I have this exact walkout basement, what is your secret for getting the framed wall to sit on top of the slab? Right now mine is doing this: also see video 260406 (7).mp4 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 6 Share Posted April 6 (edited) 1 hour ago, DefinedDesign said: Hi Michael, I have this exact walkout basement, what is your secret for getting the framed wall to sit on top of the slab? Right now mine is doing this: Not sure what you have going on there because I haven't seen the plan, but the slab should build through to the exterior as long as the main layer is framing. If you're using a pony wall with concrete on the lower half that's been dragged all the way down then you'll get what you're showing because Chief is holding the slab inside that concrete wall (even though you've pulled it down). Doing what Rene shows should force the desired behavior for even a pony wall though. Edited April 6 by Alaskan_Son Link to comment Share on other sites More sharing options...
DefinedDesign Posted April 7 Share Posted April 7 Thanks @Renerabbitt, I checked my wall settings and “Stop at Floor Below” is enabled. I appreciate you sharing the video, but I’m unable to get it to play. Thanks @Alaskan_Son, for context, the wall was originally created as a concrete stem wall when the basement was auto generated from the first floor. I then added the floor trusses, converted the walkout stem wall to a framed wall with brick on the exterior, and rebuilt the framing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 7 Share Posted April 7 5 hours ago, DefinedDesign said: Thanks @Alaskan_Son, for context, the wall was originally created as a concrete stem wall when the basement was auto generated from the first floor. I then added the floor trusses, converted the walkout stem wall to a framed wall with brick on the exterior, and rebuilt the framing. You probably need to post the plan. Too many variables. Link to comment Share on other sites More sharing options...
gravattedesign Posted April 23 Share Posted April 23 Thank you Renerabbitt ! a quick video says so much more about process. I have a similar problem with a Walk out basement that has turndown slab foundation on 3 sides and a 2x6 siding wall over 10" Fndtn. Stemwall (ponywall) on the 4th side, serving as a Retaining wall to higher elevation grade. Now I have a clear way to make this happen. Best regards, 1 Link to comment Share on other sites More sharing options...
DefinedDesign Posted May 1 Share Posted May 1 On 4/6/2026 at 6:46 PM, Renerabbitt said: also see video Hi @Renerabbitt I was able to watch your video in another browser. Thank you so much. I scrapped my other plan and started over, following your suggestions. I set the walkout wall to “Stop at Floor Below,” created the two breaks on the east and west walls, and removed the pony wall. However, when I follow the steps to check and uncheck the monolithic slab, I am not getting the same results. Here is before Checking monolithic slab: Here is what I get after checking and unchecking monolithic slab: If you or @Alaskan_Son would like to investigate the plan and possibly point out what I might be missing, I would appreciate it. In addition to the issue above, I am also having a problem with the tall wall not extending to the underside of the roof truss. Grateful for any feedback. Redraw Bplan.zip Link to comment Share on other sites More sharing options...
