GeneDavis Posted Thursday at 12:52 PM Share Posted Thursday at 12:52 PM @Steve_NyhofThanks for doing garage doors but I cannot figure how to get a door with lites in the top panel, using your .lib items. When I look at my user library in the library panel, I can see the various choices, but when I go to select a library item in the door spec dialog, they aren't there. All I have is the single panel strips, which repeat to populate the whole door opening, but I want lites in the top row. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted Thursday at 01:38 PM Share Posted Thursday at 01:38 PM Hi Gene, There should be complete garage doors in the library as well with a top row of glass. Let me know if you cannot find that. Link to comment Share on other sites More sharing options...
GeneDavis Posted Thursday at 02:06 PM Author Share Posted Thursday at 02:06 PM There are, but for some reason when I go to my user library in the door spec dialog, which is the only way to get a garage door in a plan, I do not see the same library items I see when I view my user library in the library panel. The library panel has the doors with glass, the library is not the same as when going to the user library in the door spec panel. Here I show the selection I get in the door spec. Link to comment Share on other sites More sharing options...
Chrisb222 Posted Thursday at 02:10 PM Share Posted Thursday at 02:10 PM 3 minutes ago, GeneDavis said: I go to my user library in the door spec dialog, which is the only way to get a garage door in a plan Not the only way, you can place the door directly from your Library Browser. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted Thursday at 03:33 PM Share Posted Thursday at 03:33 PM Yes, please drag the door you want from the library onto the garage wall. Thank you Link to comment Share on other sites More sharing options...
GeneDavis Posted Thursday at 03:41 PM Author Share Posted Thursday at 03:41 PM And I have now discovered that this is the ONLY way these library doors can be placed. Thanks. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Thursday at 04:02 PM Share Posted Thursday at 04:02 PM Gene, If you set you Garage Door Defaults to use the Library Object it should work for all new doors placed. Link to comment Share on other sites More sharing options...
GeneDavis Posted yesterday at 12:41 PM Author Share Posted yesterday at 12:41 PM Hi @Joe_Carrick@Steve_Nyhof@Chrisb222 this whole exercise has me a little confused. I have made garage door symbols and placed them in my user library, and can place a default garage door first, and then open the door for edit of its spec, and change it to one of my catalog doors. My user catalog doors (the ones I made) can also work by direct placement, that is, with the garage door tool active, I can click one of my doors in my user library panel and click/place it on a wall. That click/place works with the doors I have from Steve, but Steve's cannot be found if I do a garage door as described in the above paragraph. The do not appear in the library when in the dialog. See pic attached. So what is the difference between how I did my garage door symbols, and how Steve did his? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted yesterday at 12:45 PM Share Posted yesterday at 12:45 PM Hi Gene, I am not looking at my doors, but maybe as a symbol I have some option not set. I did make these in X15 while still learning Chief so it is possible I do not have something correct. When I want to use the garage doors I just put then in the plan on my garage wall and move on, so I have not tried what you are talking about. Now I am curious as to what is different. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted 23 hours ago Share Posted 23 hours ago What I am finding is that it needs to be a symbol to show up in the DBX https://my-plan.stevenyhofdesigns.com/v/W7xS5a3le3OoCEuhaSUw Here is more of why the one works and the other does not https://my-plan.stevenyhofdesigns.com/v/LfjOvLqiaAst1tXNT5CT Link to comment Share on other sites More sharing options...
Chrisb222 Posted 23 hours ago Share Posted 23 hours ago 36 minutes ago, GeneDavis said: Hi @Joe_Carrick@Steve_Nyhof@Chrisb222 this whole exercise has me a little confused. I have made garage door symbols and placed them in my user library, and can place a default garage door first, and then open the door for edit of its spec, and change it to one of my catalog doors. My user catalog doors (the ones I made) can also work by direct placement, that is, with the garage door tool active, I can click one of my doors in my user library panel and click/place it on a wall. That click/place works with the doors I have from Steve, but Steve's cannot be found if I do a garage door as described in the above paragraph. The do not appear in the library when in the dialog. See pic attached. So what is the difference between how I did my garage door symbols, and how Steve did his? Yes, I understand. The doors I created can also be selected within the DBX, regardless whether the default door is a Library Object or a standard Chief door style. I knew this when I posted and assumed it's something about how Steve created the doors, but I don't have his catalog so I didn't comment on that. Here's my catalog if you're interested: Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted 23 hours ago Share Posted 23 hours ago @Chrisb222 So based on my videos, what am I missing on my doors that could make them work? Thank you Link to comment Share on other sites More sharing options...
GeneDavis Posted 22 hours ago Author Share Posted 22 hours ago I am a long time Sketchup user and for me it's easy to create doors and then import them into Chief. The symbol-import dialog allows you when importing to do DOOR category and then when checking advanced options to create the symbol as a garage door. When I do a garage door this way it gives the ability to select it in the door spec dialog from library AFTER placing a default garage door. Doing it all inside Chief, i.e., creating a door using solids then blocking or whatever, if the same sequence of symbol creation, DOOR, then ADVANCED, then in options, GARAGE DOOR, you get the same results. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 14 hours ago Share Posted 14 hours ago 9 hours ago, Steve_Nyhof said: What I am finding is that it needs to be a symbol to show up in the DBX https://my-plan.stevenyhofdesigns.com/v/W7xS5a3le3OoCEuhaSUw Here is more of why the one works and the other does not https://my-plan.stevenyhofdesigns.com/v/LfjOvLqiaAst1tXNT5CT The difference is likely whether you add to library as a door or a doorway. One is a symbol and the other is a parametric door object. 1 Link to comment Share on other sites More sharing options...
GeneDavis Posted 14 hours ago Author Share Posted 14 hours ago @Steve_Nyhofplease describe your procedure in creating the garage door symbols. Show us with screencaps if you have the time. An example of a garage door I did is this 6' w x 8' h overhead door with lites in the third panel up from bottom. See the two screencaps of my Sketchup model. I do file>import 3D symbol and find the .skp file in my files, click to import it, then choose that it will be a door, do advanced, then under options, choose garage door from the dropdowns. That's it. Once in, the 3D symbol is opened for placement of stretch planes so the door can behave parametrically. What was your process? Link to comment Share on other sites More sharing options...
DBCooper Posted 11 hours ago Share Posted 11 hours ago Michael is correct. One of the library objects is a symbol of a door panel and the other is a full garage door. You can only choose a panel symbol from the door dialog but you can place either from the library and into the plan. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted 2 hours ago Share Posted 2 hours ago 8 hours ago, DBCooper said: Michael is correct. One of the library objects is a symbol of a door panel and the other is a full garage door. You can only choose a panel symbol from the door dialog but you can place either from the library and into the plan. ...in addition, it should be noted that when pulling and dropping directly from the library: a Door symbol (panel) will just be the panel used for whatever style of door you have specified in its Options tab. When dropped into the plan, it will respect its Size, Position, Label, Materials, Components, and a few other settings, but everything else about the newly placed parametric door object will respect your current defaults for that door type. a Doorway object (parametric) will carry over everything about the door--Door Panel settings, Casing and sill settings, Jamb, Arch, Framing, Rough Opening, Energy Values, Schedule settings...everything. If you want to just use the panel itself, then add to library as a Door and make sure none of its settings are silly unless you want them to be unique for a very specific reason. Link to comment Share on other sites More sharing options...
