winterdd Posted January 23, 2025 Share Posted January 23, 2025 Is there a way to get ride of this when doing renderings physically based? Sun shouldn't be shining thru joints in the home. Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 23, 2025 Share Posted January 23, 2025 1 hour ago, winterdd said: Is there a way to get ride of this when doing renderings physically based? Sun shouldn't be shining thru joints in the home. This was patched in X16 1 Link to comment Share on other sites More sharing options...
winterdd Posted January 23, 2025 Author Share Posted January 23, 2025 17 minutes ago, Renerabbitt said: This was patched in X16 Guess it is time to upgrade! Link to comment Share on other sites More sharing options...
Electromen Posted January 24, 2025 Share Posted January 24, 2025 Put a roof on it Link to comment Share on other sites More sharing options...
winterdd Posted January 24, 2025 Author Share Posted January 24, 2025 14 hours ago, Electromen said: Put a roof on it there is one Link to comment Share on other sites More sharing options...
robdyck Posted January 24, 2025 Share Posted January 24, 2025 The simplest fix here is to post your plan so we can see your camera settings. Or, you can post screenshots of your camera settings, rendering technique settings and lighting settings. Then someone can offer suggestions. Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 24, 2025 Share Posted January 24, 2025 I saw this type of thing (although not quite as uniform) frequently in X15, so far I have never seen it in X16. you could download the trial and see Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 24, 2025 Share Posted January 24, 2025 15 minutes ago, SHCanada2 said: I saw this type of thing (although not quite as uniform) frequently in X15, so far I have never seen it in X16. you could download the trial and see thats because we switched to multi bounce path tracing..you would still see it if you set bounces to 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 24, 2025 Share Posted January 24, 2025 you might try turning off the sunlight Link to comment Share on other sites More sharing options...
